Shoddy work from local big box store mechanic
  • Mr. Burns
    • Aug 2011
    • 3516
    Originally posted by Gregs///M
    Not sure why needing a new start requires a new cable also???
    The starter is one of the most electrically demanding circuits in the car. If the connection is dirty, unsecure, or poor, it will affect starting.
    Reason why it needed a new cable is because over the summer I replaced the clutch in the car, and had a b*tch of a time getting the starter back on once I was buttoning up the car...ended up cross threading the starter bolts and stripping a couple of nuts, and in the process damaged the wire but was still useable.
    So just opted to get a new wire while the starter was being replaced
    So, that being said-since the starter is a pivotal item in electrical distribution, would it be cause for intermittences in starting success? And shuddering at speed?
    I suspect that this might of shorted out some ignition components...Ford offers a replacement pigtail that connects from the ignition/maf that's an easy fix. Kind of want to rule out other stuff first....car isn't showing any codes or cel.
    Alternator tested at 14.3v so that's within spec (tested with volt meter, not load tested)
    Originally posted by flyboyx
    i have watched my dog lick himself off a few times
    • Gregs///M
      • Mar 2012
      • 2459
      They did a horrible job. They probably did not have any connectors or a crimper for that heavy gauge wire.
      Owner - Bavarian Restoration
      BMW and European Electronics Repair and Restoration
      www.BavRest.com
      My Feedback Thread
      Our Facebook!
      Follow our Instagram!
      • AndrewBird
        The Mad Scientist
        • 11892
        This is what I'm wondering. If you bought the car used, maybe the cable was like that from the previous owner? How should it be connected normally, a ring terminal on one of the bolts?
        I will say my mom has a 2000 Focus and that thing would not keep the battery cables clean. After several cleanings, I realized the corrosion was so bad and thick, there was almost no metal exposed. I had to use a dremel and sanding drum to remove all of it. Wire brush wouldn't touch it. Liberal amount of dielectric grease and it has been good since.
        • Mr. Burns
          • Aug 2011
          • 3516
          bought the car used, and the cable was certainly not like that previously.
          it's a brand new cable, and I would be hard pressed to imagine a fully equipped mechanic would not have a proper crimper.
          it's typically connected with a heavy gauged ring terminal along side the battery post.
          this is just mashed stranded wire being held on with a old dirty bolt.
          • Mr. Burns
            • Aug 2011
            • 3516
            furthermore, this is just another opportunity to toot my own horn with the wife to further reinforce that my 27 year old BMW has never let me\us down, and it has 3 times the mileage :-P
            • Joe G
              • 2942
              Originally posted by tobyb
              the mechanic called in sick, but sent a woman to cover for him.
              T
              fixed
              Current Car: 2011 BMW 135i, M-Sport, 6 speed
              Originally posted by lambo
              Sounds like you need a massage.
              Originally posted by kpeng
              Who the hell is Vlad?
