Blinker switch not automatic?
  • joecrouton
    • Feb 2006
    • 58
    Is the blinker switch in e30's not automatic? IE when you put the blinker on, turn, and straighten the wheel they stay on instead of flicking off? WTF? The owner said it was normal?
  • Super Sedan
    • Feb 2006
    • 551
    Nah, they should be automatic.
    • Jand3rson
      • 37587
      There's a black plastic ring mounted to the back of the steering wheel, with a little tab on it that flicks the turn signal off when you straighten the wheel after a corner. That little tab might be broken off. It's broken off on mine, but I've gotten used to turning it off myself, and now I actually prefer to switch it off myself.
      • BENdashdash
        Tom is not my friend
        • Aug 2004
        • 2506
        Since we're on the subject, I can't stand how you have to turn the wheel way far to get the blinker to shuddup... its not like that in most cars.
        • Jand3rson
          • 37587
          Case in point, that's why I like to operate mine manually.
          • joecrouton
            • Feb 2006
            • 58
            is it repairable? maybe i just didnt turn the wheel enough
            • Jand3rson
              • 37587
              The part is probably under $5-6. I bet someone here has one laying around that they didn't even know about. It's held onto the back of the steering wheel with 2 screws. All you need to fix it is a 22mm deep well to take off the steering wheel, and a phillips head screwdriver. Just make sure your wheels are straight when you take off/reinstall the steering wheel, and put the wheel back on perfectly straight.
                • 34844
                mine seems to work just fine...
