S2R Sunroof Delete?
  • Lof8
    • Oct 2006
    • 2827
    S2R Sunroof Delete?
    These things have super reviews in the e36 community. I've read about great fitment - 1/16" gap to the sheetmetal opening and mounts using factory points and hardware. You just seal the gap and go. Does anyone have experience with one in an e30? I haven't done anything new to my car in a while and am thinking of splurging on the cleared cf version. It takes 35 lbs or so from the roof!
    S50'd
    Originally posted by TDE30
    What is this faggy shit I have happened upon?
    I can always live in a M3. Can't M3 a house.
  • flyboyx
    • 8371
    pretty expensive for what it is.
    Gigitty Gigitty!!!!
    • Lof8
      • Oct 2006
      • 2827
      I won't argue that.
      S50'd
        Deleting the sunroof and the cassette isn't difficult, though it does require removing the head liner, some metal cutting, welding, filling and repainting. But it will take ~40lb off the car that is all up high. The only things you need to buy are some 4mm wire, body filler (use the metal filled variety), and paint. The wire is used to wrap around the sunroof skin to fill the gap left when the "gasket" is deleted.
        • Northern
          I like cupcakes & sh!tboxes
          • 5284
          Why not just skin your whole roof with carbon/glass, then cut the roof skin 3" from each edge and bond on your new fuhraze carbon roof skin?
          It would be even lighter
          Or you could save yourself $300 and use a sheet of lexan to cover the sunroof hole, just rivet it on using some burr washers.
          Originally posted by priapism
          Originally posted by shameson
          • george graves
            • 20003
            Is it 35 pounds just for the sunroof? Or the whole sunroof/cassette/sliders and things?
            Originally posted by Matt-B
            • mitchlikesbikes
              • Dec 2013
              • 858
              gotta be the whole assembly. the sunroof panel itself is still pretty heavy for what it is but probably only 10 lbs at the most.
              i'm probably going the lexan route for mine
              IG: @mitchlikesbikes
              • george graves
                • 20003
                Removing the cassette seems like a pain in the ass.
                • Lof8
                  • Oct 2006
                  • 2827
                  yeah, 35-40 lbs for the whole cassette. Its a track car, so I'll be ripping out the headliner - no need to be careful with the removal. I also realize I can reuse the skin, weld it, and paint it etc for cheaper. But that is significantly more work, especially since I'm not a welder or a painter.
                  Basically, I haven't done any new "mods" on the car for a couple of years now - just replacing tires and brake pads. I read a thread on bimmerforums about how nice these fit in the e36 and got an itch to do something new.
                  My car's black, so the carbon could produce a more finished look than lexan or spray painted aluminum or something "much cheaper."
                  S50'd
                  • TobyB
                    • 5298
                    Complete pain in the ass...
                    t
                    • mitchlikesbikes
                      • Dec 2013
                      • 858
                      if you're handy with an angle grinder and a heat gun its pretty easy. just messy. i got mine out in a couple hours. there's a DIY i used somewhere that was pretty helpful as far as showing where to drill spot welds and what not
                      • Nick_S
                        • Apr 2011
                        • 3658
                        Seems like for a track car, 40lbs at the very top of the car would be a worthwhile change. How close is the e36 sunroof shape to the e30? Could one of those be modified to fit?
                        91 318is M50 swapped
                        05 Honda Pilot
                        24V swap thread
                        • InNeedOfBoost
                          • Aug 2012
                          • 512
                          I know this thread is kinda old, but to install the S2R delete, is removing the whole cassette required or just the panel?
                          1991 318is - Daily/weekend track car.
                          An on-ramp is a terrible thing to waste...
                          • mitchlikesbikes
                            • Dec 2013
                            • 858
                            pretty sure you would have to remove the whole cassette.
                            but why would you even bother trying to just replace the panel with this piece and not remove the whole cassette? you're gonna spend $250+ on a new part and save like 8lbs at the most. the whole point of the delete is to get all of that weight up top out.
                            just save your $250 and do it the becauseracecar way:
                            • InNeedOfBoost
                              • Aug 2012
                              • 512
                              This is my daily. I'm not worried about weight savings. What I am worried about is the rusty panel I have that leaks when it rains even just a little. I could replace just the panel, but both my rails are broken too. Already had to replace the crank once and the gasket. Tired of replacing shit. Just want something that won't rust or leak.
                              But, do tell how you did yours. I don't even care if it looks like that. I kinda like it... would match my fender flares!
