To swap or to turbo?
  • agent
    Vice Grand Pubaa
    • 7960
    #31
    Built m20 means all the cool gadgets and features that came on the car (OBC and Check Panel) will run like clockwork after the build (minus bigger injectors, but there are ways around that)
    A swap would require extra steps of a few of those features to function normally.
    Do you just make this stuff up as you go?
    Originally posted by kronus
      • 34839
      #32
      Not entirely true.
      If those features mean something to you, then yes, keeping it OEM+ is worth it
      Uh. You realize the reason you need to adjust the OBC for a swap is the same as changing to bigger injectors? And the check panel has little to do with a swap.
      • 10yre30r
        • Jan 2010
        • 97
        #33
        BOoost it !!! Trust me !! nothing like it. If i were you i would take the time to drive a turbo e30 and then make your decision.
        • Hooffenstein HD
          • Nov 2012
          • 1388
          #34
          Turbos suck
          S54 is heavy
          Built m20 has my money. Something about the sheer simplicity of the m20 platform just hits all the right buttons. You won't hit 300whp, but there are
          Rob's NA 2.8 M20 makes 260rwkw.
          • rturbo 930
            • Dec 2005
            • 2615
            #35
            ^That's an all out race engine.
            • JinormusJ
              • 6887
              #36
              I stand corrected
              Anyone have links?
              • Hooffenstein HD
                • Nov 2012
                • 1388
                #37
                I stand corrected
                Anyone have links?
                Rturbo 930 is right, though. It's an all out race motor that probably cost more than the average S54 swap.
                • 10yre30r
                  • Jan 2010
                  • 97
                  #38
                  kamotors ride is basically stock with a turbo and pushes 400hp....need i say more.
