I got really lucky and dodged a bullet today
  • flyboyx
    • 8371
    So...I have been driving my Tech 2 for a little over a year now. I have done tons of work to it over that time. oil pan, suspension....you name it. Anyway, one of the items on my list that I hadn't gotten around to was the timing belt. It has been in the back of my mind for a really long time. every time i decided to get to work on it, there was alway some other project that demanded my attention instead.
    fast forward a year or so: today was finally the day.
    as i pulled the upper belt cover off, i noticed that the belt was actually pretty loose. i also noticed that the belt was running on the outer edge of the pulleys. it appeared that the cover was actually holding it in place. after looking even closer, i saw that the tensioner pulley was actually crooked!
    In this pic, you can see that the weld/crimp had cracked about 80% through.
    i pulled on it with my fingers and broke it completely off.
    apparently, it had been like this for some time. you can see in these two pics how the belt was flopping around on the inside of the cover:
    its hard to say, but i would assume this would have come unglued on me in the next 100 miles or so. i can't honestly say why i decided to pick today to change it out. i have noticed over the last few weeks the engine seemed to idle a little erratically. i wonder if there may have been some subliminal message from being in tune with this vehicle i love so much? maybe in the back of my head, i started thinking how she was just a teeny bit under the weather.
    btw, this is the substandard tensioner part that the bently manual says needs to be changed out with the w126 version. my guess is that this is the reason why.
    for me personally, this is the last time i'm going to be playing timing belt roulette. for those of you that have purchased or are driving a car where you have not changed your belt, hopefully this will be a reminder to do so.
    Gigitty Gigitty!!!!
  • joncrz
    • Jul 2013
    • 364
    My don't quote me list:
    I could be wrong, but I don't think it's a smog test type of thing. IIRC think it's against CA law to *sell* a dual outlet muffler as a replacement for a car that came from the factory with a single. But don't quote me on that.
    • RedReplicant
      • Oct 2009
      • 270
      You lucky bastard. Also,
      Originally posted by joncrz
      91 318is - Gone
      16 VW GTI
      07 Aprilia Tuono
        • 34844
        that's one of those crummy tensioners I'm always afraid of.
        • Zacm829
          • Jan 2008
          • 1919
          Caught it just in time! Always one of the first things to get done, along with a fresh oil change.
          1987 325i-M60b44 swap
          • e30m3s54turbo
            • Jun 2010
            • 3290
            BMW gods were watching out for you!
            • ThatOneEuroE30
              • Dec 2013
              • 8626
              Should of let it go then you would have a really good reason to swap lol. You got seriously lucky though that motor should be shelled.
              1991 318i 4dr slick top
              Mtech 2 turbo restoration
              • Sea Aych
                • Apr 2013
                • 765
                Holy crap i've been putting my Tb/WP change off for a while now too.. You've scared me straight :shock:
                1988 Atlantisblau Euro/Japanese 325i Cabriolet
                1989 Schwartz 325i - now M50 powered! - now very dead
                1998 Toyota 4Runner Limited
                My 17,000km Big NA National Parks trip!
                • Ether-D
                  • Sep 2011
                  • 2838
                  To echo everyone else, that's as close as it gets.
                  Originally posted by Andy.B
                  I was born on 3/25…
                  • LJ851
                    • 7919
                    Had to double check i was on r3v !
                    Lorin
                    The M30 is God's engine.
                    • plain325
                      • Mar 2004
                      • 163
                      Had to un-lurk, and say same thing happened to me with that same tensioner.
                      I could hear the belt flapping while the engine rpm were dropping after revving it.
                      I installed the tensioner a few months before i noticed a problem, so its not just a matter
                      of age, its just a bad design
                      There is different design tensioner, where the post attaches has a larger diameter
                      • slammin.e28
                        שמע ישראל
                        • 12054
                        Nice save!
                        Obligatory post: I never have to worry about timing belts. ^_^
                        • TurboJake
                          • 3780
                          Can't say this one enough.
                          You dodged a bullet, aimed straight at your face from 2 inches away, with the reflexes of a sloth.
                          Dear lord.
                          (I've done mine. So I'm good and not freaking out about that. Just the newly discovered post winter sittings fuel spraying EVERYWHERE underneath it now... Sigh...)
                          Leave Me Transaction Feedback
                          • flyboyx
                            • 8371
                            if it was a run of the mill e30, it already would have had a more modern engine installed. since its a factory manual trans 770 code with its original block, i have been trying to keep it pretty stock. i have another car for all that crazy stuff.
                            Dear lord.
                            kind of like the gun jammed before the firing pin hit the primer i would say: that pulley was wedged in against the water pump and timing cover. i am all but positive this is the only reason it was still more or less in place. it sure wasn't spinning very well.
                            praise jesus!
                            Gigitty Gigitty!!!!
                            • cferb
                              • 1442
                              Nice save!
                              Maybe, but it ain't any cheaper when it comes time to fix it!
