GAH, still runs lean!
  • equate975
    • Jun 2004
    • 3382
    Ok guys, I got a new o2 sensor installed, and my AFR Guage is working.
    It idles very lean, if I am coasting around and just blip the gas, right after im off the pedal I can see the LEDs run up to rich then back down to lean.
    Sometimes, if I give it about 75% of the gas pedal, it will run back and fourth from rich to lean. WOT its just lean and at about 4-4500 RPMs the car just quits acclerating, I cant get usually past those RPMs
    Once and a while though, it seems like everything works. WOT I can see it run up to rich and I can feel a big difference in performence.
    So to break it down, it still runs like complete crap. Always lean except for a few times it will get normal. if I blip the gas pedal I can see it go rich, thats about it.
    I looked at my injector rail, no gas is leaking, no codes are being thrown, nothing it just runs lean.
    What the hell gives??
    Rollin' with a Geistkuchen
  • mspiegle
    • 1026
    You should post your setup for lazy people like me. If you're using motronic, then make sure your throttle switch is working right. Also, IIRC, your car is pretty modded and you shouldn't be trusting a narrowband sensor. Spend a few hundred and get yourself a new wbo2 sensor so you can find out exactly what your car is doing. If you're really hardcore, get some EGT sensors so you can tell if your ignition timing is in the right vicinity.
    Michael Spiegle
    '01 Ford Escape / Daily Driver
    '99 M3 / Track Car
    '87 325is bronzit / wtf car
    '06 Daytona Triumph 675 / Daily Rider
    • equate975
      • Jun 2004
      • 3382
      Sorry, my car is so awesome I thought everyone would know about it :)
      S52
      OBDI
      24#
      540 HFM
      That covers the engine mods anyways.
      Would codes be thrown if an injector wasnt working? Just thinking because those things were a bitch to get in, im pretty confident all of them are clipped in, just wanna make sure though
      • equate975
        • Jun 2004
        • 3382
        Also, I just read in my guage install sheet, that "if the guage appears to be moving sluggish the o2 sensor may be faulty and needs to be replaced"
        Well joke is on them then, because my o2 is brand new.
        • EtaSport
          • 2853
          Code will be set if an injector is not working, or at least if there is a wiring/connection issue with a bank. I think you just need more fuel pressure. Your running a 3.5 bar?
          Old and improved:
          • equate975
            • Jun 2004
            • 3382
            Yeah I was going to check that, just a total PITA to get the rear fuel line off by the FPR. Is it supposed to be 3.5 for a s52 with 24#? Whats that in PSI
            • Mystikal
              Wheel Fitment Expert
              • 9602
              Yeah...narrowbands are completely useless. Get on some rollers.
              What software is running your setup?
              • WlknGenius
                • Aug 2005
                • 196
                There's about 14.5-14.6 psi per bar. So that makes around 51 psi.
                • EtaSport
                  • 2853
                  The 24s may only be 24# at a certain pressure. But I dont know if M motors have much more than 3.5 bar for fpr. If your leaning out that much with 24s, then Id say get an adjustable aftermarket unit. I also wonder if its something with the hfm. Might have to get software to work with it. You ever try a stock one?
                  Old and improved:
                  • ptownTSI
                    • Jun 2005
                    • 1265
                    if they are ford 24lb'ers they are rated at 39psi
                    • equate975
                      • Jun 2004
                      • 3382
                      JC Chip
                      • Digitalwave
                        is a poseur
                        • 6299
                        You might want to get custom software for your injectors and HFM, or get an AFPR and get on a dyno with A/F tuning. Narrowband A/F gauges are only for looks.
                        RISING EDGE
                        • equate975
                          • Jun 2004
                          • 3382
                          The Conforti chip I have is supposed to be for all my mods. Well this narrowband afr gauge has showed me that im running lean and its not getting fuel at WOT so its good enough for me :)
                          • equate975
                            • Jun 2004
                            • 3382
                            Woah woah woah.... Im getting an assload of codes now...
                            Od - Oxy Sensor
                            2A - Vehicle speed sensor not present
                            24 - Evaporative purge control valve
                            C9 - Emission (lambda) control
                            wtf? the o2 is brand new, the one I replaced was dead and it didnt throw a code....
                            Whats 24 and C9??
                            • Digitalwave
                              is a poseur
                              • 6299
                              With a gauge like that, for all you know, it could be running rich.
                              RISING EDGE
