M20 into a 318i, best of both worlds?
  • HennaE30
    • Apr 2014
    • 1965
    M60 it or go home.
    S85 it or go home.
    Originally posted by flyboyx
    how about if i yank the anal beads out of your ass like i'm trying to pull start a chain saw?
    Originally posted by Northern
    beer is my new liver cleanse.
    Henna - '84 Hennarot 325e
    Lola - '89 Schwarz 325is - being saved
    Christine - '88 Schwarz 325is - Spec E30 Racecar
    '01 White F150 Lariat 4x4 Supercrew - Daily
    Dad's '05 Interlagosblau M3
    • econti
      • May 2014
      • 1151
      Just turbo the M10
      Or M42 it
      Or turbo the M42
      • Red46
        • 1151
        Originally posted by 2mAn
        My 84 318 weighed 2400lbs with a full tank AND it had a 2.7i in it. Do it! Theres a lot of other little things that are different. No power options definitely cuts down on weight. My 86 eta weighed 2750lbs with a full tank. It was fully optioned ES, VS a bare bones 318 car. There is a difference. Both cars had full interior
        This!
        • NoM54me
          • Feb 2014
          • 158
          318 + m20 = 325. Just start there.
          • JinormusJ
            • 6887
            I think you're missing the point of this threaf
            • petrolhead
              • 421
              Originally posted by jeffnhiscars
              My 84 318i lacks power window & sunroof motors. I also think the rear drums weigh about as much as a rotor but the wheel cylinde is lighter than a caliper. I haven't looked in ages but I also think the ebrake activates the brake shoes so no extra hardware there.
              Changing over to dics in the rear and bigger front ones adds 5 kg to the car.
              Then there's the style 42 battery that's a good 12 lbs less than what's in an m20 car.
              The engine swap doesn't just add weight but it puts most of it in front the of the axle which magnified the impact on handling.
              Do the math
              Lightest E30 model was the very early 316. With 75kg driver & half a tank it's 54:46 nose heavy.
              Originally posted by ali123
              So it's about a 300 pounds diff then if you added a m20? is this because of interior or were the frame of the later models more stiff?
              thanks
              Weight differences between early and late model shells are very small. Four door is a little bit heavier but noticeably stiffer also.
              • ali123
                • May 2014
                • 54
                Oh man that's sick. I'm not sure if I want to swap a M20 or an S50. I know both will make the car front heavy but basically I'd just do a bunch of lightweight mods (carbon hood, front bumper, fenders, roll bar in the rear etc) to get the car as close to 50:50 as possible. Basically my dream goal is that beautiful NA sound with as close to go kart handling as possible. That 300 pounds diff sounds like alot. How does it feel?
                Thank you
                • Liquidity
                  • May 2014
                  • 395
                  You're still missing the point. Your 318 is not light because it's a lighter car, it's light because it has no options and has a small engine. It doesn't matter what shell you start out with, it's going to end up weighing the same in the end.
                  • nrubenstein
                    • 3148
                    The later cars also had 50lbs. of trunk ballast.
                    2002 BMW M3 Alpinweiß/Black
                    1999 323i GTS2 Alpinweiß
                    1995 M3 Dakargelb/Black
                    - S50B32/S6S420G/3.91
                    1990 325is Brilliantrot/Tan
                    1989 M3 Alpinweiß/Black
                    • JinormusJ
                      • 6887
                      Only verts did
                      Unless you are referring to the trunk tar
                      • decay
                        • 5637
                        just weight-reduce the car you have.
                        light battery (westco for miata, or look harder/spend more if you want to lose more weight). corbeau seats. those are the 2 easiest things. past that you're starting to look at stuff that will eventually bother you if you daily it (such as deleting PS/AC, for starters).
                        if you're really serious about having a lightweight car, read the grassroots motorsports & motoiq project car blogs, and look at what they do to lose weight. but be advised; they mostly work on more modern cars that have much more weight to lose. be further advised, you're going to need to put weight back into it with bracing if you want it to handle like a modern car of comparable weight (s2000, fr-s).
                        past:
                        1989 325is (learner shitbox)
                        1986 325e (turbo dorito)
                        1991 318ic (5-lug ITB)
                        1985 323i baur
                        current:
                        • ali123
                          • May 2014
                          • 54
                          Options don't really matter to me roll up windows are fine... I'm trying to start as light as possible. I understand that the engine is small but it doesn't add up to the big weight diff. 260 pounds between the early 318i and the later ones. I'm pretty sure lots of that has to do wit options, soundproofing, etc. I'm looking for a full out fun car. I just read a thread where a user mentioned that there's only a 23lb difference between a M10 and M42 with both transmissions included. I'm guessing the other 240lbs came from somewhere else then. And according to the user above brakes add 5kg. I'm planning on building this car but making it streetable as well.
                          Thank you
                          • ali123
                            • May 2014
                            • 54
                            Thanks the reason why I'm asking is because I want to start with the lightest car already (no options). Keep it street able, swap engine, add bracing, racing seats, remove rear seats, do some carbon fiber mods and basically get it to the lightest I possibly can while still being able to use it on the roads with basic necessities, AC, power steering, etc.
                            • HennaE30
                              • Apr 2014
                              • 1965
                              E30s are still fun with bigger motors such as S5x drive a and S5x swapped car and tell me you don't have as much fun.. M10 motor is a piece of crap anyway
                              • decay
                                • 5637
                                ok well my point is it's way less work to take those options out of the car you have than it is to do an entire drivetrain swap into a no-options car.
                                past:
                                1985 323i baur
                                current:
