M20 into a 318i, best of both worlds?
  • tom d
    • Nov 2008
    • 164
    #31
    its more then the weight difference between a M10 and a M20, it's about where that weight is located! since the I6 is quite a bit longer then the I4 it puts all the weight in front of the axle.
    if you don't think that makes a difference then do this; with 5 pounds in each hands, hands by your side and feet together, rotate your body. now do the same thing but with your arms stretched out in front of you. not as easy is it, well getting the car to rotate in a corner works the same way.
    • 2mAn
      Señior Mod
      • 20989
      #32
      Originally posted by ali123
      Oh man that's sick. I'm not sure if I want to swap a M20 or an S50. I know both will make the car front heavy but basically I'd just do a bunch of lightweight mods (carbon hood, front bumper, fenders, roll bar in the rear etc) to get the car as close to 50:50 as possible. Basically my dream goal is that beautiful NA sound with as close to go kart handling as possible. That 300 pounds diff sounds like alot. How does it feel?
      Thank you
      I used an aluminum M52 motor to reduce that weight up front so moving up to an engine that make 30-40% more power (maybe even more than that) with a negligible weight gain over the front wheels was a big factor in me going with the aluminum M52 vs an iron block. Im more concered with handling then all out power. I plan on getting a lighter hood to drop some more of the weight out in front.
      edit: if you dont have emission nazis to deal with I would suggest looking at a M54 motor.massive torque, aluminum block and great potential for awesome power
      Simon
      Current Cars:
      -1966 Blue Boat
      -1969 Red VW
      -1986 White BMW
      -2006 Green Thing
      Make R3V Great Again -2020
      • 2mAn
        Señior Mod
        • 20989
        #33
        just an FYI. I saw this in another thread and thought it would be useful here....
        Originally posted by SkiFree
        For those who ask, the M20 swap (sans AC) doesn't weigh any more than the M10 running AC and smog equipment.
        Simon
        Current Cars:
        -1966 Blue Boat
        -1969 Red VW
        -1986 White BMW
        -2006 Green Thing
        • tom d
          • Nov 2008
          • 164
          #34
          ^ so? a M10 without AC and smog weighs less then a M20 without AC and smog!
          • JinormusJ
            • 6887
            #35
            Yes
            IIRC, last time I checkED BMWFans.info:
            M20 weighs 270lbs dry (Iron Block)
            M10 weighs 230lbs dry (Iron Block)
            M/S5x weighs 310lbs dry (Iron Block)
            M54 weighs 295lbs dry (Aluminum Block)
            Accessories will obviously add to the weight
            • Kevinl
              • Oct 2012
              • 897
              #36
              A sunroof would be the only real weight difference in a shell other than that everything else can be deleted power windows probably add 10lbs max
              1989 BMW 325is Lachsilber metallic 5 speed
              2007 BMW 335i KARMESINROT 6 Speed manual
              2011 BMW X5 35I
              • F34R
                sLaughter
                • 12376
                #37
                Twin turbo S85 is the only logical thing to do.
                Instagram: @BWeissLeather
                Current cars:
                ~ '87 325 M30B35 swap
                ~ '87 535
                ~ 01 540 Msport 6spd
                ~ '06 X5 4.8is
                • HennaE30
                  • Apr 2014
                  • 1965
                  #38
                  That's what I said! I've seen someone cram an S85 in an E30 M3. It actually looked pretty wicked.
                  Originally posted by flyboyx
                  how about if i yank the anal beads out of your ass like i'm trying to pull start a chain saw?
                  Originally posted by Northern
                  beer is my new liver cleanse.
                  Henna - '84 Hennarot 325e
                  Lola - '89 Schwarz 325is - being saved
                  Christine - '88 Schwarz 325is - Spec E30 Racecar
                  '01 White F150 Lariat 4x4 Supercrew - Daily
                  Dad's '05 Interlagosblau M3
                  • econti
                    • May 2014
                    • 1151
                    #39
                    Yes
                    And remember, the M20/M50/M5x add the weight right at the nose. This in my experience makes a hell of a difference to the characteristics of the car.
                    • JinormusJ
                      • 6887
                      #40
                      Yes
                      4-cylinder bmw engines are generally pushed back to the firewall leaving a large gap between the radiator/engine
                      • lukeADE335i
                        • Apr 2013
                        • 1389
                        #41
                        The M10 doesn't sit that far back in the engine bay - the distributor is at the back of the head. The M20 sits much closer to the firewall.
                        My e30: OEM+ with M30B35
                        • econti
                          • May 2014
                          • 1151
                          #42
                          That is true, but even so M20 has 1.5 more cylinders at the front. And my M42 sits pretty hard up against the firewall, so it's well different compared to the 6.
                          With that said though, would be interested to try an alloy M52/54 to see how they compare.
