how to tell what year drive shaft
  • ptownTSI
    • Jun 2005
    • 1265
    once a driveshaft is out of the car, how do you tell what year it is from. I think one of mine is from an 87, but i want to measure whatever it is that is different on the 8/87 and under.
  • ptownTSI
    • Jun 2005
    • 1265
    well? i'd like to know so i can order the proper one.
    • Digitalwave
      is a poseur
      • 6299
      there is a technical forum on this web site, it is located here. use it
      RISING EDGE
      • equate975
        • Jun 2004
        • 3382
        You such a stickler for the tech forum :)
        seriously though, just about every post in the general forum can be put somewhere else in r3v. Might as well not even have a general.
        Rollin' with a Geistkuchen
        • rs4pro3
          • 5808
          simple, measure the size of the guibo
          85 325e 2.7 ITB'd stroker
          • ptownTSI
            • Jun 2005
            • 1265
            but what is the DIFFERENCE in the shaft, i know the guibo sizes are different. why do you need to buy a different center bearing?
            • rs4pro3
              • 5808
              becuase the chassis mount is different. FYI All m20 driveshafts non ix driveshafts are basically the same, in 87 certain cars got the larger guibo, and from 9/87 on BMW changed the way the center support bearing mounted. But either the old or new bearing will work on either an early or late driveshaft or vise versus.
