This should help with the issue
M60 vs Boosted M42
Turbo setups caught a bad rap over the years because of people being really stupid... for instance, when I was younger and didn't know jack shit about cars I had a "knowledgeable friend" help me turbo my miata. He, I shit you not, tuned it "by ear". Amazingly enough it lasted a few thousand miles before blowing up.
Step 1: Always rock a wideband, even if people tell you "you'll be good, I've got a sweet ass map that works great on my car, use it".
Step 2: Let off the throttle if you start getting a stoich leaner than 14ish:1
Step 3: No mystery step
Step 4: Profit
Just follow these steps (especially 2) and you'll avoid most of the disasters that could cause you worry.
Originally posted by TobyB View PostTurbo plumbing is expensive...
t
the cheapest POWER solution is to take an oem 325 and bolt on turbo,,, easy 350 ponies
with a good setupSveinbjörn Hrafnsson
E30 CABRIO V12 M70B50 ///
ALPINA B10 BITURBO 346 @ 507
E34 550 V12 JML
Finnish wisdom : If you want to Win,, hire a Finn
http://alpina.123.is/pictures/
with a good setup
And guys, I'm deciding wether to boost or to swap, not what to boost after I swap it haha. Kinda kills the budget aspect of it.1991 318i Sedan
Im confused as to why you think turbo plumbing is expensive? intake shit is dirt cheap, exhaust is cheap if you can weld (i cant weld but i made that shit happen because jew), jakeb has m42 turbo mani's that im sure are affordable. If tuning is your biggest scare then have someone else do it. Easy as that. Or do jakes kit. Ive heard nothing but great reviews and if youve seen any of his builds you'll know the quality is top. After this winter Im thinking about getting an m42 car to dd and Ill definitely get his kit. den i haz twin m42t's :)
Originally posted by MF DOOM View PostIm confused as to why you think turbo plumbing is expensive? intake shit is dirt cheap, exhaust is cheap if you can weld (i cant weld but i made that shit happen because jew), jakeb has m42 turbo mani's that im sure are affordable. If tuning is your biggest scare then have someone else do it. Easy as that. Or do jakes kit. Ive heard nothing but great reviews and if youve seen any of his builds you'll know the quality is top. After this winter Im thinking about getting an m42 car to dd and Ill definitely get his kit. den i haz twin m42t's :)1991 318i Sedan
Originally posted by MokinWeet View PostI was only nervous about tuning because of how green I am to boost. After sleeping on it I'm actually wanting to play with a tuning program. Am I going to be disappointed with the power I get from an m42 for the price?
The added bonus is that with a boosted M42, you get very close to stock M42 economy when off boost around town.
Going to boost mine once some more money comes in. Aiming for 250-300hp.
I helped a friend with a cheap M42 turbo build some years ago, stock internals except for M50 non vanos 135mm rods for super low compression :) He gave that engine a real beating and it worked great! I think it was like 230whp due to too much back pressure, otherwise 300whp should be fine.
E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
E30 M50 6 spd 764whp @ 24psi.
E30 M20 6 spd 675whp.
