Why do BMW's I6 engines generally run hot?
  • socalife
    • Jun 2014
    • 177
    But it takes time for it to turn on when i need it most
    • Todd Black 88
      • Oct 2007
      • 3449
      Huh? It is supposed to do that. Hook it up to a proper sender, of the right Temp, and it will turn itself on and off where it is supposed to.
      I have only an electric fan on my car, and the fan is hooked up to a two speed fan switch at 80*c and 88*c. My car sits a hair below center all the time. On the hottest of days, driving hard for hours on end, it never goes over half.
      Originally posted by codyep3
      I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
      2001 silver/Blk 325 cabby. SOLD
      2002 325xit Sil/blk. SOLD
      2010 F650gs twin
      • efficient
        • Feb 2012
        • 3312
        you guys think the fan shroud is crucial?
        • redsubdivisions
          • Feb 2011
          • 1762
          E32 fan switch? I have that running on mine as well if so.
          1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
          2012 Passat TDI - DD Duty
          2008 GMC Yukon XL Denali - Kiddie hauler/grocery getter
          • Kevinl
            • Oct 2012
            • 897
            Should be e36 318is switch
            1989 BMW 325is Lachsilber metallic 5 speed
            2007 BMW 335i KARMESINROT 6 Speed manual
            2011 BMW X5 35I
            • Bearmw
              • 1323
              A shroud is helpful for any fan.
              • Mr. Tasty
                • Jul 2011
                • 3421
                of course it is.
                2014 Alpine White 335i MSport
                (Daily Driver)
                Full Mperformance Aero
                KW V2 Coilovers
                VRSF Catless Downpipes
                • Hooffenstein HD
                  • Nov 2012
                  • 1388
                  2.7i swap with an M42 radiator and an eBay 16" pusher fan wired to a 316ti fan switch. For the most part the temp gauge stays just under the half way mark but it creeps up to just over and the fan turns on. The fan will only ever turn on after 10+ minutes in stop, go traffic conditions though. Can drive it hard through the hills for hours on end and it stays below half.
                  With all that said, if I open the bonnet at any given time, it will blast out quite a bit of heat. Probably from all the metal heat soaking. Nature of the beast.
                  • HennaE30
                    • Apr 2014
                    • 1965
                    My car only runs slightly warm during the 110 degree summers here, but that's partly because I'm missing a shroud clip and I'm never highway driving, always light to light.
                    The engine bay heat is just the heat being purged from the motor
                    Originally posted by flyboyx
                    how about if i yank the anal beads out of your ass like i'm trying to pull start a chain saw?
                    Originally posted by Northern
                    beer is my new liver cleanse.
                    Henna - '84 Hennarot 325e
                    Lola - '89 Schwarz 325is - being saved
                    Christine - '88 Schwarz 325is - Spec E30 Racecar
                    '01 White F150 Lariat 4x4 Supercrew - Daily
                    Dad's '05 Interlagosblau M3
                    • TheTacoMan
                      • Nov 2011
                      • 2308
                      Shouldnt be that way, my intake manifold is almost cold to the touch after a couple of pulls. With meth;D
                      • nyChris
                        • Apr 2012
                        • 395
                          • 37832
                          Originally posted by socalife
                          I guess i wasnt descriptive enough, but what i mean is i dont have stock fan that hooks up to the alternator belt because it doesnt fit.
                          Why doesn't it fit?
                          Yes.
                          Classic BMW Specialists
                          Grover Beach, CA
                          www.BimmerHeads.com
                          • socalife
                            • Jun 2014
                            • 177
                            I put a bigger radiator in thats why, but i could make it fit by shaving the edges but the fan would be to flat and wont be effective. Plus i have no room for a shroud. Anyways tomorow im taking it in to put a switch that should turn on automatically, that way i would only have a fan in front of the radiator. Btw does anyone know if certain antifreeze cools better then others? or are they all the same?
                            • socalife
                              • Jun 2014
                              • 177
                              Btw, thanks for the link i wish i would've searched but i intended to make this thread about the heat wave i get from pulling the hood with a m50 rather then the m40 i used to have. It turns out its just heat build up from all the mpower under the hood hahahaha( exhaust manifold and what not)
                              • nrubenstein
                                • 3148
                                I guess i wasnt descriptive enough, but what i mean is i dont have stock fan that hooks up to the alternator belt because it doesnt fit. Instead i bought an electric fan that actually cools the engine really good. The only problem is that i wired it to a misc. button since i didn't know their was another way. So, i either drive with it always on which ends up leaving the needle on the first white tick or i try to keep an eye on it and let it bounce around the half tick or i end up forgetting which resulted me into almost overheating twice. Anyways, i guess i understand our cars are normal but can i have more info on hooking it up to a timer. Thanks!
                                Pick up the diesel fan and it'll fit with a standard E36 clutch (and some fiddling). Grab a 324td fan clutch, and it'll fit easily.
                                2002 BMW M3 Alpinweiß/Black
                                1999 323i GTS2 Alpinweiß
                                1995 M3 Dakargelb/Black
                                - S50B32/S6S420G/3.91
                                1990 325is Brilliantrot/Tan
                                1989 M3 Alpinweiß/Black
