Why do BMW's I6 engines generally run hot?
  • Swanny
    • Mar 2012
    • 2834
    #31
    Get a proper electric fan relay? If needed you can throw and override switch in as a fail safe. Can ever set up a timer for cooldowns after the car is off.
    Swanny!
    SUCKERS.
    • socalife
      • Jun 2014
      • 177
      #32
      Its ok im going to get a 80-88 timer installed timer, thanks for the help /thread
      • the dubshow
        • Apr 2014
        • 55
        #33
        not to get far off topic, Ive read on the cluster temp gauge the needle should be at the half or below mark.
        I found this for an e34. on my m20b2.5, the needle hardly ever moves past the first quarter (144), even when temp should be normal.
        • dnguyen1963
          • Nov 2011
          • 2649
          #34
          If you have the correct t-stat then the needle should be between 195 and 182 (90 and 83 C) marks. I know a lot of you guys in the hotter climate have 70 C t-stat and the needle should be around 153 mark.
          • kickinindian
            • 2327
            #35
            This is gonna be another mods plz delete thread....I can feel it
            • dnguyen1963
              • Nov 2011
              • 2649
              #36
              Why? I need some non-sense to fill my day.
              • socalife
                • Jun 2014
                • 177
                #37
                I didnt say anything wrong, i got my questions answered and the thread is done. Go be cool somewhere else gosh
                • Julien
                  • 7471
                  #38
                  Originally posted by MR 325
                  Your car needs work. They don't all run hot. None of my cars ever have an issue.
                  You should not need the aux (electric) fan AT ALL to keep your E30 at the correct temp unless you're actually using the AC.
                  false, or else they wouldn't have added a thermocouple to the side of the radiator :)
                  Build Threads:
                  • digger
                    • Nov 2005
                    • 6141
                    #39
                    MR 325 is correct, if the aux fan comes on when A/C is not on then you have an issue. Even on a modified stroker engine i could never get the aux fan to work unless the A/C was on. it just never got hot enough even on a 113 summer day.
                    i would look at at as a backup device at best and if it comes on regularly the cooling system needs to be fixed
                      • 37832
                      #40
                      I've owned multiple E30's with the AC removed which means there is no AUX fan to come on... All of my E30's have been well maintained and have NEVER had cooling issues. Even on the hottest 110 degree California days under full load uphill or sitting in traffic my cars would NEVER pass the halfway point. So I'll stick with my advice in saying that you should never need the AUX fan to keep a car cool if the AC is not running.
                      Classic BMW Specialists
                      Grover Beach, CA
                      www.BimmerHeads.com
                      • BLACKCHARM88
                        • Jun 2014
                        • 563
                        #41
                        Because they can...
                        • socalife
                          • Jun 2014
                          • 177
                          #42
                          To MR325, are you talking about an m20 or m50? Because i have an m50b25tu and their is barely any room for a stock fan which is why i installed the aux...
                          • camshaftgsxr
                            • Aug 2011
                            • 416
                            #43
                            the aux fan wont keep the engine cool by itself
                            BroWorks.com Bro is a lifestyle
                            • Julien
                              • 7471
                              #44
                              Non a/c cars don't have an aux fan since there isn't the obstruction of a condenser in the way of the radiator. Tow a 1500 lbs (or full euro-style and tow 3000lbs - lol) trailer uphill and that aux fan will come on ;D
                              Build Threads:
                              • slammin.e28
                                שמע ישראל
                                • 12054
                                #45
                                Why do BMW I6 engines have 6 cylinders?
