Dyno Results +VIDEO
  • matt325is
    • 409
    Dyno Results +VIDEO
    Well, went back to the dyno today. Turned out be a great day at the dyno! FINALLY!
    So, here is the scoop, these figures are at 10psi, and if we tried to go higher, it would detonate (most likely cause by too hot of plugs, so I bought colder ones after the dyno, I will gap them tomorrow and see how they do). We tried 15psi, and it was a NICE gain, but had to shut it down once it started detonating.
    266.50 rwhp , 273.11 rwtq
    319hp and 327tq at the crank.
    I am very happy with these results. They said I would get some gains if I had larger exhaust (mine is only 2.5").
    Pics, the low figures are from last year when it was a 2.8l low compression, with 19lb/hr injectors and NO TURBO.
    This was at 15psi, but had to shut down.
    And here are my new painted tail lights.
    VIDEO
    7.55mb 1:39
    Right click -> save target as
    1st clip = 10psi run
    2nd clip = 15psi run (4krpm)
    3rd clip = speedometer on 10psi run
    matt
  • bimmerphile
    • 3495
    Re: Dyno Results
    Kickass! I was right on the money with the crank estimate (or pretty dang close).
    Good bye E46 M3's
    • Sean
      • 5793
      AHH!! SWEET!!
      That's an insane amount of power. VERY impressive. Lets see wht it does with bigger exhaust now? 8) :D
      Offtopic: Just noticed your new signature, Kris. And, your car is all mine! :D
      - Sean Hayes
      • Stu Mc
        • 4083
        Very sweet numbers Matt. I am glad your frustrations are over and that you have solid numbers. 8)
        No doubt....goodbye E46 M3, E39 M5.....
        • aaron_silva
          • 1785
          :up: Awsome work!!!
          • SlammedE30
            • 741
            Beeee-youtiful!!!! Wish I coulda been there :( Oh well, Eurofest! :D
            -Ted
            • jweb
              • 959
              Wow, I have to get a turbo someday.
              Jamie Webster
              '89 325is - sold :(
              '96 Miata - sold
              '01 M5 - sold
              '02 Civic Si
              • reelizmpro
                • 9527
                Man look at that torque with 15PSI....damn! pretty insane. BTW, this is with an ETA crank right? How about some water injection? or knock sensing technology? Damn good numbers.
                88 M3 - LACHSSILBER
                89 M3 - ALPINEWEISS II
                • bimmerphile
                  • 3495
                  No shit.
                  Hell, even if he ran at a happy medium, like 12PSI as "high boost," it would reach 350 by the time it was done i'd imagine.
                  • LikeCDoos
                    • Jan 2004
                    • 2522
                    wow those are some beautiful numbers
                    • TCD
                      • 438
                      Beautiful! That's great Matt. I am really encouraged by your numbers. Did you get the a/f ratio plotted? The engine is falling on it's face at higher rpm. This is likely due to it going really lean. You should be able to run alot more boost than 10psi. I doubt the 2.5" exhaust is the culprit.
                      What do have for a turbo? I know it's a T04B but what are the specs?
                      Todd
                      TCD
                      1985 euro 535i
                      503rwhp/485rwtq
                      • decay
                        • 5637
                        i have been waiting for that dyno chart for SO F***ING LONG...
                        thank you :)
                        past:
                        1989 325is (learner shitbox)
                        1986 325e (turbo dorito)
                        1991 318ic (5-lug ITB)
                        1985 323i baur
                        current:
                        • ETA fro
                          • 168
                          insane numbers
                          is that on 91 gas
                          • e9nine
                            • 1890
                            Re: Dyno Results
                            matt
                            :twisted: :firehop: , finally a successful run ! Congrats Matt...gradually straighten the petty issues and you're good to go. Nice to see your hard work pay off. You gonna look at the a-f as suggested by Todd?
                            So you're among the most powerful e30s on here r3v now. We should have a sticky or hall of fame sticky for yourself, Mike Swale, Barry R, Stu etc ;)
                            • gstuning
                              • 833
                              Excellent work
                              Fixing the timing will create more power and also try and work on smoothness
                              hope nothing happened while pinging,
                              Could you have dropped the boost until it didn“t ping/knock ?
                              How is the smoothness of the engine?
                              EDIT:
                              Looking at the graph max power is at 5200rpm while still maintaining almost max torque,
                              expect more then 300rwhp when you get max power at 5700+
                              Gunni
                              @ Prodrive / Aston Martin Racing
