Here's how much power is needed to make an e30 do 200mph
  • Silverdogz
    • Aug 2012
    • 168
    420hp
    so true.. never let them know where you live..I almost ended up in jail when I was raping young women on craigslist
    • 34839
    420 isn't that much. not sure I'd want to do 200mph in an E30 or any car outside a racetrack..
    • Red_liner740
      • Oct 2014
      • 127
      If only it was that simple.
      • ELVA164
        • 4861
        Took me 488bhp with only 4 gallons of gas in the tank.
        • efficient
          • Feb 2012
          • 3312
          the aero dynamics on a e30 suck.
          • ELVA164
            • 4861
            Originally posted by efficient
            the aero dynamics of a brick suck.
            ftfy
              • 34839
              ~.33 cod isn't too bad. what the E30 really has over modern cars is a small frontal area. a modern "3" series has a lower cod but the frontal area is much greater.
              • digger
                • Nov 2005
                • 6105
                i've data an old "motor" magazine article for the 325ix and 325i it lists the Cd as 0.38 which isn't surprising given its hardly a sleek design.
                of course Cd x A is the proper way to compare cars
                  • 34839
                  the earlier ones were worse than the later ones. I'm pretty sure I saw the face lift 325is at .33
                  • digger
                    • Nov 2005
                    • 6105
                    data was from 1987, but with different spoilers, rideheights, bodykits, rear wings and wheel widths etc results may vary
                      • 34839
                      yeah, pretty sure the earlier cars were a bit taller, or at least had a bigger air gap up front. BMW did actually wind tunnel test the facelift design, the is spoilers are supposed to reduce drag by a couple %.
                      also, if you want brick shapes - E30s hardly have any square corners compared to say, a 1979 ford Fairimont. ;)
                      • Silverdogz
                        • Aug 2012
                        • 168
                        IIRC, the M3 actually has a worse drag coefficient than the standard iS.
                        • ELVA164
                          • 4861
                          That's due to the extra downforce the M3 produces.
                          • Stanley Rockafella
                            • Aug 2011
                            • 4060
                            also, if you want brick shapes - E30s hardly have any square corners compared to say, a 1979 Volvo 245DL ;)
                            ftfy
                            • george graves
                              • 19996
                              Wider tires cause a good increase in drag as well - or so I've heard.
                              Originally posted by Matt-B
