Not a single valid word in that title - I love it.
Anywho, all of you cult-belonging M42 guys should pick up this month's GRM. Last month they did a bunch of maintenance to a 318i(s?) that they picked up and got it to 127whp (on a 200k mile motor). This month, they answer all of your questions and bolt up a D/A supercharger - after lord knows how many people said it couldn't be done - to an M42. End result was 187hp to the wheels, IIRC, and they cover ALL the details.
They also cover the 5 or so cheapest cars to get started in road course racing. It's a good read - highly recommended.
What issue is this, exactly? June 2006?
They don't sell GRM over here in Germany :( :( :( ---- I CAN'T GET A COPY TO READ!!!
Anyone have the May 2006 issue? I want to know what sort of baseline they got and what bolt ons they did. I'm getting excited about the prospects of a S/C M42.
Its a good issue... a lot of background on the M42 and M44. Here's some basic info, although if you are serious about doing this I would recommend buying this issue.
Baseline (hot-muggy Florida weather):
* 0-60 in 9.52 sec (BMW claimed 9.8 in literature, this car had over 100k miles on it and slightly shorter tires than stock).
* Mustang chassis dyno reported 119.5 hp at 5600rpm and 118.8 lb-ft of torque at 4500rpm. AF ratio looked good.
1st mod: Magnecor wires
125.7hp at 5800rpm and 121.8 lb-ft at 4650rpm. They state this is too much for a set of wires, but if you take the "noise" of the dyno and a potential 1.5hp gain over old worn wires this sounds about right.
2nd mod: New clean OEM BMW air filter
126.7 hp at 5650 and 123.9 lf-ft at 4700rpm.
3rd mod: TMC chip
129.5hp at 5800 rpm, no change in torque.
4th mod: Supersprint cat-back exhaust
no weight change over OEM, about $300 cheaper though.
131hp at 5900rpm.
Wrap up:
less than $1500 spent, 0-60 is now 8.45 sec and 7000 rpm redline, 60mph still takes going into 3rd gear.
It also goes through braking and suspension upgrades.
3rd mod: TMC chip
131hp at 5900rpm.
Wrap up:
Hope that helps.
Get that issue from GRM.
EDIT: All horsepower and torque is at the wheels.
Thanks. I went to the site, and couldn't find that issue on back order. I'd gladly pick it up if I knew where to find it.
