I failed as a man. Here is my public apology regarding my e30.
  • roguetoaster
    Biggus Tippus
    • 7830
    #31
    Originally posted by lambo
    I end up replacing mine at least once a year. Probably not necessary but I end up doing it anyways
    When I replace parts unnecessarily I do try to give away the still good bits like wipers, air filters and tires to other E30 owners who need them. As there is always the person who is just starting out and maybe can't swing quick replacements under their budgets (most of us have been there).
    • lambo
      Captain Scene Points
      • 10953
      #32
      That's a good idea. I think I still have a couple laying around.
      • Exodus_2pt0
        • 5943
        #33
        I'll take a used timing belt please, those damn kits are expensive. Not worth the cost new.
        No E30 Club
        • roguetoaster
          Biggus Tippus
          • 7830
          #34
          You should collect all of the used timing belts and make the worlds longest belt. Which isn't a record that I've ever heard of.
          • slammin.e28
            שמע ישראל
            • 12054
            #35
            Go around the world with M20 timing belts....
            ....until it breaks.....
            ....and the world stops....
            ....and we all die.
            • markseven
              • Sep 2006
              • 5327
              #36
              Originally posted by Jims5543
              You should always "zero mile" a car when you acquire it.
              Before the rims, lowering springs, exhaust etc.. the priority should always be on the maintenance items.
              I check the easy maintenance items on the first visit as a prospective buyer. It gives a clear indication of how the car has been maintained and cared for.
              Then the official pre-purchase inspection if I am serious about the car. The best $100 you will spend on a potential new used car is the PPI.
              I Timothy 2:1-2
              • elmandatario
                • Mar 2012
                • 85
                #37
                Tbh I was expecting to see a crashed e30 from the title
                Ig: el_mandatarioe30
                • totheredline
                  • Jun 2013
                  • 762
                  #38
                  I put leaves in the my Toyota pickup's airbox. Depending on what type of leaves, Ive seen anywhere from a 25-200hp gain. make sure the leaves are soggy before you put them in, it helps lubricate the upper cylinders.
                  = Heidi 1988 325 -> 335i. 7200rpm built M30
                  • ELVA164
                    • 4861
                    #39
                    Helpful.
                    • Gunner_1886
                      • Feb 2015
                      • 58
                      #40
                      I was going to try this but wasn't sure what sort of liquid to use to get the leaves soggy - will just regular tap water work?
                      1998 M3 - Sold
                      1991 318i - Sold
                      1998 323is - Daily
                      1986 325es - Project
