Rant: doing shit properly
  • econti
    • May 2014
    • 1139
    Background: My brakes are worn. Rotors were almost gone and so were pads.
    Bought slotted rotors and new pads for all four corners.
    Today I start doing the work. Wheel off, caliper off, all going swimmingly. Old rotor off... What's this? The bolt that holds the rotor on looks a tad funny. And it's a different size.
    So I put the new rotor on, and lo and behold the locating bolt doesn't sit properly under the surface of the rotor. So the wheel doesn't sit flat.
    I then compared it to the locating bolt of the other side.
    It's a totally different size.
    What the previous owner has done, is stripped out the bolt, found one the same thread but 6mm instead of 5mm, and just ground down the head of it so that it fits. But it only fits the stock rotors, and it's just shit.
    So people. There might be some of you reading this that try to half-ass stuff.
    Please fucking don't.
    I don't care if you're flat stony broke. Do not kludge stuff like this as it will just bite you, or the next owner, in the ass.
    If you're going to do something, take your time, make sure everything is clean and done properly.
    I've had to deal with shit like this with everything that I do on the car and it's just painful. Hopefully I'll be able to get it to my standards at some point, but god damn.
    It also goes to show why you buy a car from someone who takes care of it.
  • Das Delfin
    • Sep 2014
    • 2293
    My car's seat belt receptacle wasn't bolted in to the seat when I bought it (don't ask me why) so the po's solution was to wrap the seat belt around the hand brake. Took me about an hour to fix it, including driving to the hardware store.
    • Herr Faust Schinken
      • Feb 2012
      • 3580
      I'm honestly not sure how people strip those out so often, maybe they are trying to use L-drivers or something. they aren't even supposed to be that tight, its just there keep the rotor seated when you take the wheels off
      88 325is Five Speed
      Lachssilber
      • Rook12V
        • Nov 2011
        • 93
        Its not specifically their fault. moisture gets in there and they seize up. Set Screws as we call them seize all the time. They're not even really *that* important, but I've never let a car leave the shop without them being in/correct.
        • econti
          • May 2014
          • 1139
          I've had to deal with a lot of stuff like that. Even just simple maintenance things, like the balljoints in the control arms were totally stuffed. Changing arms takes 15 minutes. Nope, too much effort.
          At least I now know a lot about doing things to E30s.
          It'd be easy if you use actual allen key L ones, yeah. I've done it.
          But the difference is that if I do it and strip it, I replace the bolt.
          Not had a problem after getting correct tools though.
          • econti
            • May 2014
            • 1139
            And now while trying to separate the front brake lines the fitting on the hard line has stripped. Brilliant. That's going to be nice and easy to fix I bet.
            Still haven't split them either.
            • slammin.e28
              שמע ישראל
              • 12054
              Is what anti-seize is for.
              Doing a proper job means using the proper "tools"
              • slammin.e28
                שמע ישראל
                • 12054
                Snap-on (or other QUALITY brand) flare nut wrench.
                If that doesn't work, put some Vise-grips on the flare nut wrench to keep them from spreading.
                If that fails.....fuggit, use Vise-grips on the nut. Going to have to replace shit then anyways.
                • IronFreak
                  • Dec 2012
                  • 3702
                  Consume these and it won't really matter as much mate......
                  Instagram @rebellionforge
                    • 34839
                    then use copper anti seize. they will never rust or seize up if prepped right and not tightened too much. all you need is your pinky finger to get them snug enough.
                    also, those bolts cost like 15 cents. lol.
                    • slammin.e28
                      שמע ישראל
                      • 12054
                      2012 Oil Can Breweries, Ft. Worth, TX
                      Mate ;)
                      • IronFreak
                        • Dec 2012
                        • 3702
                        Mate ;)
                        Shut up before I mate you right in the ass.
                        • slammin.e28
                          שמע ישראל
                          • 12054
                          As long as Blunt will be there....
                          • lukeADE335i
                            • Apr 2013
                            • 1385
                            Yes - I was just going to comment - get another bolt. Although if the thread is stripped in the hub, which I presume it is since the PO went for a bigger bolt, then it's probably a good excuse to replace the front hubs and wheel bearings. Might as well fix the problem right this time around (although personally, I'd go to a fasteners joint and get another 6mm bolt with the correct size head rather than doing something dodgy - will cost 30 cents vs. over $100 for new hubs!)
                            LOL on the Fosters pic... you can't actually buy it down here, despite being the 'Aussie' beer :)
                            My e30: OEM+ with M30B35
                            • Dirty325ix
                              • Sep 2012
                              • 689
                              So you gonna start paying for my car repairs?
