Why you need a torque wrench
  • e30onBBSs
    • Dec 2014
    • 1347
    #61
    Hmm I believe you guys but how hard and how expensive is it to find them?
    BMW tech
    Umass Amherst
    05 wrx sti
    • 15Michaeljoseph
      • Aug 2013
      • 1693
      #62
      garage sales, estate sales, antique rummage shops, pawn shops.... they're out there haha. I mean its not like they're going to do the job so much any differently than, say, the kobalt wrenches i bought at lowes, but there's definately a difference in build quality and badass-ness. It's all a preference.
      --Mike
      (OO=[][]=OO) For Life
      • AndrewBird
        The Mad Scientist
        • 11892
        #63
        You can score old wrench sets off eBay for cheap usually. I prefer Proto brand stuff. They are more of an industrial tool company than an automotive one and make some really nice stuff.
        • Aleksey
          • Feb 2011
          • 336
          #64
          Just finished reading the first page, might already be wrong but that it's not 'easy' to get out type of bolt and it does not mean that the guy over stressed it.
          I sheared bolts like this after shop forgot to tighten then and wheel forcefully removed the head as it almost broke loose. Also it could be an attempt at removal of a wheel lock with stripped head.
          If it's latter that metal is going to give you hard time; the best thing I found is BOSCH hammer drill. Tap it them let the beast break the shit out of that bolt.
          You might try welding since the wheel is off but you going to have to weld it to handle good amount of PSI. Another option is to dremel it deep in - pattern (cutting the hub in process) and getting it out that way. That thread will still be usable but not 100%.
          Founder @ Maintenr. Take control of your vehicle maintenance.
          • e30onBBSs
            • Dec 2014
            • 1347
            #65
            I'm going to do the bearings. I pulled one off, and the "race" is still there. Why is it bad? I took off the part that's going to be replaced?
            BMW tech
            Umass Amherst
            05 wrx sti
            • Axxe
              • Aug 2004
              • 3355
              #66
              You have to get that race off. Best way is to cut a thin slice with a small cutoff disc, about halfway through staying away from the stub axle. Then hit it with a good steep chisel and a good whack from a hammer and it should split the race the rest of the way through and then it will slide right off.
              Keep it slideways!!
              • jalopi
                • 2370
                #67
                if the bearing was bad you definitely want the old race off. basically both the balls inside the hub and the thing stuck onto your spindle are wear items - if you put a new bearing on the old, stuck on race in lieu of the new race, and the old race was irregularly worn, the new balls in the bearing would fail prematurely and you'd need to do the job all over again
                • e30onBBSs
                  • Dec 2014
                  • 1347
                  #68
                  So I need a new race as well? Thanks for the info!
                  BMW tech
                  Umass Amherst
                  05 wrx sti
                  • e30onBBSs
                    • Dec 2014
                    • 1347
                    #69
                    Alright I just read the bentley section on it and I am going to rent a puller once I have the parts. Thank you guys for all the help! I'm going to be away for three weeks and hopefully I will be able to drive it for a couple days beforehand!
                    BMW tech
                    Umass Amherst
                    05 wrx sti
                    • jalopi
                      • 2370
                      #70
                      new hubs/bearings come with new races, though that'd make for an interesting conversation at the parts store
                      • e30onBBSs
                        • Dec 2014
                        • 1347
                        #71
                        Yea at first I didn't know the race was a small piece, I was like why do they want me to remove that whole thing? Then I watched a video and it's a small circle and I was like oooooooh!
                        And it's important to remove because if I put the new one on it would hit the old race and basically be a spacer that maybe wouldn't even allow for the axle nut to be threaded. I would have been like yea shit something is wrong baha
                        BMW tech
                        Umass Amherst
                        05 wrx sti
                        • e30onBBSs
                          • Dec 2014
                          • 1347
                          #72
                          Got both sides ready for new hubs bearings pads studs!
                          BMW tech
                          Umass Amherst
                          05 wrx sti
