Why you need a torque wrench
  • ravenlord89
    • May 2012
    • 111
    Originally posted by e30onBBSs
    Why do you think it broke? I bet it was fine then they drove it and clunk sometime later the uneven stress ripped that one off. What's your theory?
    Wheel bolt heads do not shear off while driving unless there is a metric shit ton of force on them. And then they will shear together not a single bolt. That was broken off putting it in, or taking it out. Which should be well over 500ftlb of force, as unless I am mistaken the wheel bolts on these cars are grade 10.9, which means they can take an insane amount of stress before shearing.
    As for snapping all of the bolts on everything on this car, it sound to me like you need to soak the entire car in PB blaster. Then you need to invest in a torch set. Fire is the magical bolt remover.
    1990 BMW 325is 5spd Black
    2005 Subaru Impreza 5spd
    2015 Yamaha FZ-07
    • e30onBBSs
      • Dec 2014
      • 1347
      Originally posted by rturbo 930
      Alright, follow me here. You said:
      Unless I'm misunderstanding, you're saying here that if you can't get the rusted bolt out, that you're going to be in the market for the entire strut assembly. What I'm saying, is that if you can't get the allen bolt out (and the broken lug, let's not forget about that), that you don't need an entire strut assembly. You will only need a new hub assembly, which is also your wheel bearing. And as I said earlier, quite honestly, it's going to be easier (but more expensive) to buy a new wheel bearing and hub assembly than to deal with drilling out two bolts in your hub, which are probably rusted in solid.
      Make sense?
      Yea it makes sense but since I am not an expert on wheel bearings I'm not 100% sure of the procedure/ what parts come along with the wheel bearing job. Thanks for helping me learn! And the strut market would be used, but much less rusty and bad. Is $240 for the assembly as well or JUST the bearings?
      Could I do this? https://www.fcpeuro.com/products/bmw...FcmPHwodCTIAAw
      And new rotors/ springs from the other thread?
      BMW tech
      Umass Amherst
      05 wrx sti
      • rturbo 930
        • Dec 2005
        • 2625
        For $240, you get what's in the picture, so, bearings and hub. But that's $240 for 2 FAG brand bearings. There's other brands for less money (like what you linked), but I don't know how they are in terms of quality. I generally do a search here for a given brand/part before I buy, but I'm guessing those Meyle's will be fine. If you don't have a Bentley manual yet, download one. It's available online somewhere, search for it and you'll find it. I haven't actually done wheel bearings yet, so I can't help you there.
        You need new rotors for sure, your springs are rust and pretty ugly, but I'm not sure they need to be replaced immediately, unless they're a lot more rotten than they look.
        • e30onBBSs
          • Dec 2014
          • 1347
          I have a bentley no doubt! I think it would be a good project and I think on my passenger side it may really need them, the wheel can kinda wobble when it's off the ground. I read up on the pelican article and it sounds like it definitely be the bearing, because visually everything else seems decent although a bit rusty. I will probably leave the springs as they are for a while, the rears are going to be swapped first for more low when the time comes.
          Thank you turbo and everyone else!
          Ben
          BMW tech
          Umass Amherst
          05 wrx sti
          • e30onBBSs
            • Dec 2014
            • 1347
            Do these parts pass the r3v quality check? I don't want to put crap on my car!
            https://www.fcpeuro.com/products/bmw...rotor-40406121
            https://www.fcpeuro.com/products/bmw...nt-34111161936
            https://www.fcpeuro.com/products/bmw...ew-34111123072
            BMW tech
            Umass Amherst
            05 wrx sti
            • jalopi
              • 2370
              OP i wouldn't replace the wheel bearings "just because", they don't get replaced at regular intervals, they get replaced when they make noise.
              heat that bitch up, if you don't have a real torch at least use a MAP gas torch (just like a handheld propane torch from home depot, they're in yellow bottles though) and try to get the stuck bolt out.
              buy yourself a decent tap & die set instead of the wheel bearings, chase the threads on the hubs and buy yourself a wheel stud conversion kit
              • e30onBBSs
                • Dec 2014
                • 1347
                Earlier I tried to drill the bolt out, would it work if I heated it then hammered on a socket? The inner hexagon shape is gone now. I want to avoid wheel bearings/ hubs if I can. Thanks Jalopi!
                BMW tech
                Umass Amherst
                05 wrx sti
                • jalopi
                  • 2370
                  wait what inner hexagon shape? we're talking about your broken wheel bolt, right? what are you gonna hammer a socket onto? pics if you can
                  • e30onBBSs
                    • Dec 2014
                    • 1347
                    There is that lug and that rotor place holder allen bolt. It's rusted in there and I know they aren't supposed to be re-used. So I have 2 bolts to get out,
                    1. Lug bolt threads
                    2. and the retaining bolt, looks just like this
                    Since my rotors are off, I have access to the outside of this bolt, so I could probably bang a socket onto it. Yesterday I gave it a shot and it wouldn't budge, and the socket would fall off. I figure if it was wicked hot it would be more willing to form to the socket and maybe even fuse together? I also read about JB welding a bolt head onto stripped bolts like the allen one then breaker-barring them off now there is something to grab onto? Has anyone ever had success with that, or should I just get a torch because basically every bolt under the car is like these?
                    Thanks r3v :D
                    BMW tech
                    Umass Amherst
                    05 wrx sti
                    • frolf
                      • Nov 2005
                      • 191
                      Originally posted by jhaurimn
                      Are you soaking everything in pb blaster before you try taking them out? If not, you definitely should or you will break every bolt on the car from the looks of it :P
                      As someone from Minnesota, this is a classic comment.
                      PB blaster / liquid wrench is how every project starts on Minnesota cars.
                      Dan
                      • e30onBBSs
                        • Dec 2014
                        • 1347
                        hahahahaha is it more rainy there or snowy? MA seems to be the same way. Luckily for me my town doesn't use salt so no extra rust when I will be cruising around the block ;D
                        BMW tech
                        Umass Amherst
                        05 wrx sti
                        • frolf
                          • Nov 2005
                          • 191
                          Both in MN. I live in Montana now where we have snow but no salt.
                          Dan
                          • jalopi
                            • 2370
                            oh, that... fuck those little screws dude, they're unnecessary, you don't need them. they're really only there to simplify assembly at the factory
                            if you convert to wheel studs in the future (which i highly recommend) it'll be even less of an issue when you take the wheels off the car
                            • e30onBBSs
                              • Dec 2014
                              • 1347
                              Just got a torch and have hit the lug thread like 4 times with a short wait in between. It doesn't seem like it's going to budge.
                              What to do from here? Wheel bearings/ hub? Just put in another lug and attached my breaker bar then angled that so it was on the ground, then I stood on the vice grips and the grips always slip! What a PITA. Any other suggestions? Does this mean wheel bearing and hub?
                              Just went at it again, and something inside the hub started to move before the lug.. It made a loud creeking noise. This sucker is really in there. Could that noise have unsettled something inside that could be trouble? I am probably just going to remove everything on the other side too and see if that side is good so I know what parts I need. then do the hub and bearing on this side. Also need to do the timing belt because who knows when that was last done.. I can relate to PO problems now!
                              BMW tech
                              Umass Amherst
                              05 wrx sti
                              • varg
                                Florida Turbo Man
                                • May 2014
                                • 3425
                                Heat and impact are the magic formula for removing that stuff. If the internal hex screw is stripped you can't do anything but drill it out, but you said the rotor is off? Do you have a welder or know someone who does? The ideal solution is to weld a nut to that broken lug bolt, that should be enough for you to be able to get it out. If not, your best bet is to grind some flat spots on it, get it really hot, and try to work a socket on there, or use a pipe wrench/flat jaw vice grips. You don't want to have to drill that big sucker out, not going to be fun to do with a hand drill and the bit to do it will be $$.
                                IG @turbovarg
                                '91 318is, M20 turbo
