Anybody know how to remove this?
  • Rouvld
    • Sep 2014
    • 569
    I'm getting ready to send all of my trim pieces off to get powder coated, I have all of the trim off (un-bent thank god) but the lower piece on the rear pop out window. I took the window off and it looks like the chrome piece is riveted to the frame. Anybody know how to get these off?
  • KI4UJO
    • Jun 2011
    • 642
    If I remember right, you have to drill the rivets and then slowly pull everything apart.
    IMG_0145 by Jonathan Martin, on Flickr
    • Rouvld
      • Sep 2014
      • 569
      Do you know what size rivets these are?
      • jalopi
        • 2370
        drill them out and measure the hole. you can buy rivets based on the hole size and material thickness at mcmaster.com
        • AndrewBird
          The Mad Scientist
          • 11898
          Looks like 1/8" to me.
          • TobyB
            • 5296
            BMW seemed to like to rivet the pop- outs. The 2002's rear chrome was rivetted in place, too.
            The ti solves that problem by not having any trim.
            Yes, you drill it. If you use a 1/8" bit, you can then use a 1/8" rivet when you reinstall it.
            t
            • Rouvld
              • Sep 2014
              • 569
              OP here, do any of you guys know if they're any type of glue or silicone holding the glad to the chrome trim? I removed the ruvite buy the trim is budging.
              • zachcollard
                • Jan 2013
                • 139
                I've done this several times and there most definitely is some type of adhesive, in my experience its been a very sticky epoxy like glue and over time it becomes very dry and almost impossible to get off in some cases. Just work it from the edges, id recommend paint thinner, a thin flat head and vice grips. Good luck!
                Sent from my A0001 using Tapatalk
                • bastianshaw
                  • Jan 2007
                  • 2210
                  just pc them
