possibility of entire front end replacement?
  • ptownTSI
    • Jun 2005
    • 1265
    A guy locally has whole front end for sale, he says its in good shape with 150k on it. My front end has bad control arms, bad bushings, and a bad right front wheel bearings.
    i've already bought new M3 cabs, and an SKF hub/wheelbearing, should get new lemfoerder arms as well, or just swap in the entire front end replacement, and if everything is good, keep my M3 cabs and hub for a later time. i can get the front end for less than a pair of lemfoerder arms.
  • uflnuceng
    • Apr 2005
    • 1049
    swapping is easy, just disconnect the steering column from the R&P (mark for easy alignment), support the engine back where it meets the tranny with a jack stand, disconnect suspension at strut towers, all ABS and brake lines, then just drop the subframe (4 bolts on unibody, 2 on engine mount bushings). Its heavy as hell though, but I did it solo in a weekend.
    • redbull 325is
      • 7471
      i wouln't fuck with it IMHO.. just get new parts and be done w/ it
      Juliej
      Build Threads:
      • uflnuceng
        • Apr 2005
        • 1049
        i'd get it just for spare parts... maybe his strut housings are in better shape than yours.
        • Garageaholic
          Freestyle Fabricator
          • Dec 2005
          • 5204
          it depends on the array of tools you have.. and patience...knowledge.. and perhaps a little help
          Recent Rebranding!!
          E30 SM62/S62
          E30 M60 V8
          E30 M30 Big 6!
          Instagram.com/garageaholic
          Youtube.com/garageaholic
          • ptownTSI
            • Jun 2005
            • 1265
            this might seem like a really dumb question, but if i switch to koni adjustables do i keep my strut housing?
            • chuckybob
              • Aug 2004
              • 952
              i hope you have a lot of money or a lot of free time.
              : : 1984 318i : : PNW E30 Crew : : Sold!!
              Now becoming the R3vlimited Pro3 car
              http://www.r3vlimited.com/board/showthread.php?t=93780
              • Digitalwave
                is a poseur
                • 6299
                There is no sense in spending all the time swapping the parts for used parts with 150k on them. Buy new ones.
                RISING EDGE
                • Sean
                  • 5793
                  Buy new wear items, using used wear items are pointless - unless you literally have them laying around, and the car isn't a performance machine. Like, if I had some 84 318i as a daily, I'd put used parts on it. lol
                  Yes, you need the strut assembly no matter what.
                  GC's only modify the strut - but it still remains.
                  - Sean Hayes
