resurfacing head. is .008 too much?
  • dsphil
    • 495
    My machine shop told me that my m20 i head need to resurface the head at .008. Is it doable or I need new head? I think .006 was the max. any thoughts will be appreciated.
    327is
    325es
    325es
    318is
    Fiesta ST
    E46 M3
  • Cabriolet
    • 9620
    you should be ok. there are 3 dimples on the bottom of the head. if they are gone then you will need to get a thicker gasket.
    Much wow
    I hate 4 doors
    • AndrewBird
      The Mad Scientist
      • 11898
      .005-.010 is pretty standard for decking a head. You should be fine.
      • barbierij
        • Sep 2012
        • 1294
        I always thought that you could only shave until the "shave dot" is completely flush with the rest of the head (gone).
        circled in red here:
        any more and you need a thicker gasket.
        FS NY: two Audiobahn A235HC amps and audiobahn 1farad capacitor
        Saab/GM tech2 programming
        My for sale thread
        1990 325iX for sale or part out
        Did you buy something from me? Please leave feedback!
        Originally posted by K20RI_211
        And I have to ask if you make a hobby out of thread-bombing with retarded questions?
        • TobyB
          • 5293
          .008 is like, just a mild polish... You're in good shape.
          You CAN cut it as much as you want- it's just that you then have to make sure all
          the rest of the stuff is ok (valve clearance and timing, compression, etc)
          t
          • dsphil
            • 495
            For some reason they think is too much. I told them to proceed and I will have to get a thicker head gasket. Will see what it was like when I pick it up. Thanks for the inputs.
            327is
            325es
            325es
            318is
            Fiesta ST
            E46 M3
            • Hawk
              • 549
              I have taken an M20 head down that far with no issues after a timing belt tensioner failed.
              You should be fine.
              Summer '85 E24 635csi Winter '88 E30 325iX, I lose 25% of my hp before I even turn the key.
              • AndrewBird
                The Mad Scientist
                • 11898
                I think some Pro3 guys shave it down like .015" or some crazy amount. At that point though, the head is one time use only.
                • getouth
                  • Jan 2010
                  • 3343
                  You're good!!
                  FEEDBACK:
                  http://www.r3vlimited.com/board/showthread.php?t=316212
                  BMWCCA #398608
                  IG @yagayo38
                  "The Best E30's were built with two camshafts four cylinders and sixteen valves!".
                  • TobyB
                    • 5293
                    jeeze, I run M10 2002 heads cut 0.100" in the race car just as a matter of course-
                    I can't see such a mild cleanup making enough statistical difference to notice on an M20.
                    It's just not that much...
                    t
                    • dsphil
                      • 495
                      I have a little concern about this machinist now. They are telling me that the head is warped and they are putting it in the oven before they can resurface it. When they said oven, they don't mean cleaning it.
                      327is
                      325es
                      325es
                      318is
                      Fiesta ST
                      E46 M3
                      • TobyB
                        • 5293
                        Yeah, you can heat and twist a head to try to straighten it.
                        I could never figure out how...
                        t
                        • gwb72tii
                          • Nov 2005
                          • 3864
                          Heat can release internal stress from manufacturing that will cause warping
                          “There is nothing government can give you that it hasn’t taken from you in the first place”
                          Sir Winston Churchill
                          • steve68
                            • Jan 2013
                            • 457
                            My S14 head was straightened in the oven then surfaced, don't remember how much,
                            88 M3 Lachsliber glass top, 90 IS project,
                            • dsphil
                              • 495
                              All these stuffs the machinist said is new to me. Maybe I shouldnt worry too much.
                              327is
                              325es
                              325es
                              318is
                              Fiesta ST
                              E46 M3
