TCD Turbo 325i - it's ALIVE!! Update with PICTURES
  • TCD
    • 438
    No pictures from the other side?
    Not today.
    TCD
    1985 euro 535i
    503rwhp/485rwtq
    • Jordan
      • 12913
      Not today.
      :cockbloc:
      https://mtechniqueabs.com/
      • randomtask37
        • 3154
        Not today.
        :cockbloc:
        98 M3/4/5
        • 325is_e30
          • 567
          more pictures please
          • diegom6
            • 4447
            Todd, I have a curiosity, in your Turbo Kit, do you include a oil pan with the hole made already or you have to tell at the buyer make the hole. I know you put the kits, but what happens if you sell the kit outside of your area?
            Well, I'm not so interested , but probably many that are thinking of buying your kit does.
            Also, the pipes are coated with something or will be? Let us know...just curious :D
            Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
            • TCD
              • 438
              Diego,
              The customer must drill a hole in the oil pan. The charged air pipe and intake piping will be powder coated.
              Todd
              TCD
              1985 euro 535i
              503rwhp/485rwtq
              • diegom6
                • 4447
                Diego,
                Todd
                Like I was guessing...ok, the pipes requires a bit of trim, make holes or so...or just almost plug and play for say it in some way..?
                • TCD
                  • 438
                  Diego,
                  I am not sure I understand your question. This will be a complete bolt on kit.
                  Todd
                  TCD
                  1985 euro 535i
                  503rwhp/485rwtq
                  • diegom6
                    • 4447
                    Diego,
                    Todd
                    sorry for the inprpopper write or aspeak, many times it's difficult speak or write in the correct form.
                    you said all, Bolt On, that answer my questions...I meant if the charge pipes requires some work to make them fit in the engine bay...but like you said it's bolt on, that's what counts... :D
                    • ///M3Hopes
                      • 24
                      [img]http://groups.msn.com/_Secure/0RACeAtcRjDKqBPY*Ryy0xYYXs62GXFIwmaFqfggBdJxrTO*qX NN0ly0A6Mo2vGHRcZavO0Z7I2fNXlghO4DuzqcD916XdO1vlPF IdsDVqo8/IMAG00100.JPG?dc=4675461903831695514[/img]
                      whoa whoa...ur using an FMU? (Rising Rate Adjustable Fuel Pressure Regulator) From all my experiences in the use of these things they aren't good after about 8 psi..the fuel pressure becomes significant enough to make the injectors run at 100% duty cycle..not to mention the fuel pump can't keep up.
                      Are you actually using one or am I just lost...
                      • TCD
                        • 438
                        Yep, you are lost. They are a great tool. We use them in all our turbo cars. The one from BEGI works great. We have used them up to 20psi with great success. We also use injectors twice the size as stock.
                        Todd
                        TCD
                        1985 euro 535i
                        503rwhp/485rwtq
                        • ///M3Hopes
                          • 24
                          Todd
                          ok, so since your probably using some sort of piggyback or standalone management to control the idle with the way bigger injectors..why not just include the whole rev range and alter the maps for it instead of using the FMU...ya know...just get rid of it altogether
                          • TCD
                            • 438
                            We are using the stock engine management with 24lb injectors a 535i AFM, the BEGI FMU and a MSD6BTM. Nothing else. For whatever reason, most people discount the stock ecus ability to adapt to bigger injectors.
                            Todd
                            TCD
                            1985 euro 535i
                            503rwhp/485rwtq
                            • E30godz
                              • 1524
                              see!!!! what did i tell ya.
                              • Rob
                                • 8166
                                all these cockteases, I want to see some dyno charts
                                BEERTECH
