sr20det or sr20vet
  • aydenharle
    • Sep 2015
    • 3
    sr20det or sr20vet
    Im going to do a engine swap on my e30 and i was wondering what enigine i should get between the sr20det and the sr20vet or maybe any other ones. i was wondering what the differences between those engines where and if they would be suitable as a daily dive. thanks :)
  • steve68
    • Jan 2013
    • 457
    neither, leave those in a 240
    88 M3 Lachsliber glass top, 90 IS project,
    • Exodus_2pt0
      • 5943
      I'd go with a Gallo 12 or a Gallo 24.
      Or just turbo whatever is in it.
      No E30 Club
      • beatup86
        • Mar 2014
        • 89
        The sr20vet only came in front wheel drive platform and only in japan. The sr20 should be left in a Japanese car, sell ur e30 buy a 240 and then u can choose one if these engines
        • Exodus_2pt0
          • 5943
          Gotta disagree here. I'm all for foreign swaps. I did a 5.0 e30 and hated it after a while. Was constantly working on it, but I think the problem was more the engine selection.
          I just think of OP were serious, he wouldn't be asking a forum which motor to use. Most people who are going to tackle a motor swap just do it.
          Seriously though, SR20DET is not a drop in swap. The 5.0 actually was surprisingly easy. But, if I were to build another e30 it would be an m20 turbo. I regret not doing that instead of the 5.0
          No E30 Club
          • Jb325is
            • 2137
            I don't think they SR20 is good enough to warrant a swap. RB would be worth the trouble IMO, but I would turbo an m42 before swapping SR20 for sure
            - '88 m54 coupe
            <3
            • Reichart12
              • Aug 2012
              • 2163
              Ahh classic
              Instagram: Reichart12
              • redsubdivisions
                • Feb 2011
                • 1762
                +1.
                1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
                2012 Passat TDI - DD Duty
                2008 GMC Yukon XL Denali - Kiddie hauler/grocery getter
                • TimeMachinE30
                  • Jun 2014
                  • 3749
                  ACS S3 Build / Dinan 5 E34
                  • steve68
                    • Jan 2013
                    • 457
                    [quote=Exodus_2pt0;4485599]Gotta disagree here. I'm all for foreign swaps. I did a 5.0 e30 and hated it after a while. Was constantly working on it, but I think the problem was more the engine selection.
                    as in a 5.0 Ford 302??
                    If I was to do a V8 swap in one of these, I'd have to go LS, light and HP rating, the all iron V8 had to make for a nose heavy e30
                    • e30 gangsta
                      • 3877
                      What? You cant be serious. Sure lets add weight, Spend a bunch of money on the rb to modify and upgrade the oil pump just to make 350hp. Rb's are garbage, the only ones worth building are 26's and I doubt he's going to do that.
                      The sr20det is a great engine swap candidate. I suggest you go with the s14 blacktop instead of the s15 sr. (s15 sr is 6 speed has a weaker trans, and requires the diff for speed signal. )
                      Also if you must go vvl it is expensive, almost as much as the sr swap easily $3000+ You can use that money to get a tune, injectors, and a gtx2876r. Youll make 400rwhp easily all day on e85.
                      There multiple sr e30's out there and its one of the best swaps out there for an e30 if you have the patience to wire it up and fab the mounts.
                      Theres a 700rwhp neo vvl sr e30 in my neck of the woods. Trust me if you build an sr its a great engine. I myself have built 4-5 of them and I love them.
                      Goodluck.
                      • Exodus_2pt0
                        • 5943
                        [QUOTE=steve68;4485638]
                        Yup, actually though the 302 isn't all that heavy, the blocks are thin and crack past 400ish hp. Also, the engine sits further back than the stock I6. I didn't notice any difference in the twisties, but then again I didn't track itneitherm.
                        I just kept dealing with vibration issues, and finally got tired of yanking the trans every month.
                        No E30 Club
                        • steve68
                          • Jan 2013
                          • 457
                          I think you go VW 1.8 T or VR6,
                          • TobyB
                            • 5256
                            JATO rocket or go home.
                            t
                            • ahrensNW
                              • Mar 2015
                              • 1716
                              ^to be honest, that sounds like more of a honda swap. Falcon 9 or bust.
                              Hank Ahrens
                              1984 Alpine Coupe
                              1978 911sc
