First E30: Buying Advice
  • badguise
    • Sep 2015
    • 57
    Hello All,
    After digging around these forums and elsewhere, I'm ready to buy my first E30. They're honestly the only cars I'm interested in. I'm a beginner and have a lot to learn, but my plan is to educate myself with this purchase. The R3V forums have been a huge help and now I'm at least fairly comfortable discussing E30s.
    On Sunday I'm going to take a look at this one. The new asking price is $3,500.00 and the seller mentioned that the steering rack will need to be replaced at some point. I definitely need a car soon, so waiting for "the one" may not be an option right now. This is the best I've found in my area so far.
    Can any of you experts chime in? What do you think? What should I look for and what should I ask the seller? I'd like to be as prepared as possible when I check it out on Sunday.
    Also, if this is the wrong place to post this thread please let me know! Thanks!
  • QUKBMER
    • 8178
    Take it to a shop and pay to have it checked over first is what i would do. Ask when the timing belt was changed last 4 years or 60.000 miles which ever comes first.
    • 24v e30
      • Jul 2015
      • 66
      This 318i does not have a timing belt, so don't worry about that. It uses a chain. Still, having a shop look it over completely for other issues is sound advice. Good luck!
      1991 318i stock-ish (daily)
      1991 318i s52 (sold)
      1991 318is (sold)
      • QUKBMER
        • 8178
        Sorry i didnt click for a pic of the car, just make sure its not over heated.
        • cleanasse30
          • Jan 2014
          • 436
          Since there is rust on the body, def bring a jack and take a look under the car, or as mentioned before take it to a mechanic and get an inspection. Clunks while shifting are usually bad engine mounts, tranny mounts, or rear suspension bushings. If you aren't too experienced with cars, just take it to a reputable mechanic for an inspection and ask if you can take a look at the car while its on the lift as well to see if there is any rust you wouldn't want to deal with.
          You may also consider going further away if you can find a cleaner one. Southwest has cheap flights, and road tripping home in a good condition e30 is a blast!
          2.7i Stroker Turbo Build Thread
          90 325i | 95 Miata
          • 2mAn
            Señior Mod
            • 20954
            Terry, you newb. Its not a bad looking car. Try to find a member who lives closeby to go check it out with you
            Simon
            Current Cars:
            -1966 Blue Boat
            -1969 Red VW
            -1986 White BMW
            -2006 Green Thing
            Make R3V Great Again -2020
            • QUKBMER
              • 8178
              lol
              • badguise
                • Sep 2015
                • 57
                Right on - thanks, guys.
                I'll look around for shops in the area for an inspection.
                You think members of the forum would be willing to look at the car with me? That would be amazing! I'll contact some strangers and give it a try.
                Based on the info in the ad, do you think the price seems fair? I know that it's subject to change upon closer inspection of the car, but does it seem to be in the right ballpark?
                • Staszek
                  • 2533
                  Out of all the things you can look for I think rust is the most important, most other things can be fixed easily (even rust can if its not too bad) but a clean body to me was the most important.
                  • aegul44
                    • Apr 2015
                    • 396
                    1. Valve cover seals
                    2. Oil pan seal.
                    2. Check all plastic hoes in engine compartment, especially intake boot
                    3. Steering rack might be reservoir leak. They tend to crack due to being plastic. cost less than $25
                    4. Check cluster, odometer gears break down. Some people use the car with broken odometer which means you really don't know the real mileage of the car.
                    5. Dashboard cracks.
                    6. Check for rust, especially jack points, wheel well, inside of the trunk, around rear license plate light, under door, under the car and exhaust.
                    7. Check for transmission rear main seal.
                    8. Check body panel alignments for any accident.
                    9. Door locks. Usually center locking system doesn't lock all panels.
                    10. Check window switches and sunroof.
                    and many other standard procedures for buying used cars.
                    Esquire E30 Build (87 325i Vert)
                    Ultimate Tanning Machine
                    • badguise
                      • Sep 2015
                      • 57
                      Thanks everyone. Unfortunately the car was sold on me before I could schedule the inspection, but I'll keep it all in mind as I continue shopping.
                      • 101
                        • Jul 2011
                        • 764
                        I've found that most of the people here on R3V love these cars and are always willing to meet up with a fellow enthusiast and help out where they can. Provided, of course that an appropriate amount of beer is being offered up for the help and advice that you're looking for.
                        101
                        The E30 collection:
                        1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
                        1987 325is - Delphin / Black Sport (son #3's)
                        1987 325i Convertible - Triple Black
                        1989 325iX Coupe - Diamondschwarz / Black Comfort
                        1990 325iX Coupe - Sterling Silver / Grey Sport
                        1981 Fiat 124 Spider 2000 - Green / Tan
                        1998 Volvo V70 GLT - White / Tan
                        1998 Volvo S70 T5 manual - White / Taupe
                        2001 Ford Windstar - Silver / Grey (parts hauler)
                        2006 Lexus GX470 - White / Tan (tow rig)
