Difference between e and i. WTF...
  • e30crazie
    • Feb 2013
    • 858
    I just installed the new head on my 89 325i. So when I picked up the head from the shop I was told that the valves needed to be adjusted. I did the install and because I've never done a valve adjustment, I took it to a local mechanic that I was told was a German car mechanic for a quote.
    Here is the kicker...
    So I drive up in a noisy e30 and ask the cost of a valve adjustment. He looks at my car and say;s "oh its an e30", he said that if I was not aware that these cars had noisy engines. So he asked if it was an e or an i. I told him it was an i then he scratched his head and said no... this is an e . I told him nooooo, this is an i . After a mild discussion, he told me that all 4 door e30's were i's and all 2 door e30's were e. After I giggled internally, I told him "ah... Its ok, I'll just adjust them myself.
    I tried to explain the difference between ETA and i cars but he did'nt want any part of my explanation LOL.
    Again, needless to say that I walked away from this job. Someone that knows the model because its popular but doesn't know the true difference is not worthy of touching my m20.
    I am not sick, I am twisted. Sick makes it sound like there is a cure.
    1991 318is Diamantschwarz Metallic
    1989 325i Alpine White
  • lambo
    Captain Scene Points
    • 10953
    If you can do a head swap you can do a valve adjustment. It's super easy.
    • CarsonE30
      • Jun 2015
      • 2124
      C'mon, you lol'd, I would've lost it, props to you for keeping it together!
      C6Z
      S2K
      VeloN
      • YosemiteSam
        • Apr 2011
        • 1303
        Wow, where did he even get that idea?
        • e30crazie
          • Feb 2013
          • 858
          I'm doing it tomorrow. I saw some pretty in depth vids on you tube and feel comfortable enough to do it.
          I just never done it so I figured I'd take it to the experts.
          • papag1234
            • Feb 2012
            • 297
            I did a valve adjustment like a month or two ago for the first time. Put the car in 5th and push it to turn to TDC each time since I have LSD. It was fairly easy. Just make sure you have the right feeler gauge because I did it without and that was a bitch.
            • ttrousdell
              • Nov 2009
              • 1770
              what was the quote for the valve adjustment?
              The Build:
              • modernist
                • Apr 2014
                • 283
                Or just jump pins 11 and 14 in the diagnostic connector to bump the starter.
                1986 327i
                transaction feedback
                DIY thing
                meh
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  I like to pull the spark plugs and then just use a ratchet on the front of the crank.
                  • modernist
                    • Apr 2014
                    • 283
                    but then you have to go through the trouble of pulling the plugs and reaching the crank bolt with a ratchet.
                    1986 327i
                    DIY thing
                    meh
                    • ELVA164
                      • 4861
                      The gearbox is the important part of the equation (being a manual), not the differential. Open diffs can use this method. Unless one were to roll the car with one wheel in the air/missing, I suppose.
                      • e30crazie
                        • Feb 2013
                        • 858
                        I ended up pulling off the radiator and turning the crank with my 1/2 inch socket to make the adjustments. I bought a feeler set and used that to gauge my valves. I installed the radiator back and installed all of the stuff I pulled to get to access. Vioala... My engine feels tight and silent. Mission accomplished.
                        On a side note... When I installed my head and timing belt I forgot to put in the hook bracket behind the timing belt cover. I didn't think it mattered to much but it actually does. When I pulled the radiator off, I thought what the hell, I might as well install it as I had access to the dist cap. I noticed that I had some ground rubber on the timing belt cover, as I looked further, I saw that the brand new belt had been rubbing on a groove inside the cover. I pulled it off a little and installed the hook and noticed a huge difference in the clearance. I didn't think it mattered too much until my belt started to rub. Thank god I took the long route and found out before more damage occurred.
                        • e30crazie
                          • Feb 2013
                          • 858
                          He quoted me 150.00, I don't know if that cheap or not but just the fact that our debate was about, I was not going to let him touch my car.
                          • ahrensNW
                            • Mar 2015
                            • 1716
                            That seems fair if the parts are included. The parts being the head gasket and rtv lol.
                            Hank Ahrens
                            1984 Alpine Coupe
                            1978 911sc
                            • TobyB
                              • 5256
                              My father in law is convinced that his 325e had a 4- banger.
                              Some things are just not worth arguing about.
                              t
