Difference between e and i. WTF...
  • steve68
    • Jan 2013
    • 457
    Put Wheels and Tires on my 90 IS, daughter now drives it.
    Tuffy in Orlando, has a alignment special, 59.00$, drive up, need a alignment, oh BMW's are $149, really, oh that ones lowered it's going to be 189.00, BMW's are difficult to align, said really? tie rod adjustment? lowered cars are difficult to align, thanks have a nice day,
    88 M3 Lachsliber glass top, 90 IS project,
      • 34827
      Originally posted by AndrewBird
      I like to pull the spark plugs and then just use a ratchet on the front of the crank.
      I just ratchet on the crank. Don't even bother with the plugs.
      Although, you could use it as an excuse to swap the plugs.
      • htown318is
        • Feb 2012
        • 301
        ^ any other way is just non-sense.
        • ELVA164
          • 4861
          I know what you mean, but to complete the picture you should know Nando looks like this:
          • LowR3V'in
            • 4209
            What I like to do is lift up a corner and turn the wheel in gear.
            I know you didn't ask but funny we all have different ways to do it.
            • e30onBBSs
              • Dec 2014
              • 1347
              Or you can do them in the firing order and only have to turn the crank 360 deg total =P 22mm wrench
              BMW tech
              Umass Amherst
              05 wrx sti
              • anabolice30
                • Jul 2013
                • 946
                Originally posted by TobyB
                My father in law is convinced that his 325e had a 4- banger.
                Some things are just not worth arguing about.
                t
                ?? Has he ever looked under his hood? Even when I was 16 and a complete scrub I could tell which e30s were 6s and which were 4s by counting spark plug wires..
                • AndrewBird
                  The Mad Scientist
                  • 11897
                  I find the compression can make it hard to hit TDC perfectly as it wants to roll past the top. Removing the plugs eliminates that problem. Plus it's just easier to turn with the plugs out.
                    • 34827
                    Doesnt have to be exactly tdc. The cam lobe just has to point down. Theres like 100 degrees of tolerance on the back side of the cam lobe.
                      • 34827
                      I do it the same way :-)
                      • ButtJuice
                        • Dec 2009
                        • 2609
                        I'm confused. I thought all 4-doors had s14 motors and 2-doors housed m10s?
                        1991 318is - Sold
                        1986 325 - Sold
                        Instagram - Lamoursum
                        • e30crazie
                          • Feb 2013
                          • 858
                          Or when they are advertised as V6. That really makes my skin crawl.
                          I am not sick, I am twisted. Sick makes it sound like there is a cure.
                          1991 318is Diamantschwarz Metallic
                          1989 325i Alpine White
                          • e30crazie
                            • Feb 2013
                            • 858
                            I made sure the lobes were pointing down. Also since the plugs were removed, I placed a long screw driver in the socket and made sure my piston was all the way up.
                            • 5Toes
                              • 9836
                              valve adjustments are so easy lol just use your head and understand how a camshaft interacts with the valves. that said, I can do one in about 30 minutes or less, its really easy - even if you use a 22mm wrench on the crankshaft by hand.
                              loos eccentric 10mm nut, stick feeler gauge between eccentric and valve and then push the eccentric down with your finger. tighten. done.
                              I find rolling the eccentric down by hand, or more like just your index finer, makes a good, appropriate, and uniform drag quickly and easily.
                                • 34827
                                I got the spring tool. I've only used it once though - but it is pretty nice. it puts exactly the right amount of pressure on the eccentric every time.
