oil level sensor necessary?
  • cpandrewschmidt
    • Oct 2014
    • 88
    Hi all,
    When lifting my head gasket I think I snagged the oil level sensor and it snapped where the two clips come together. Or it might have been busted all along, I don't know.
    This part about half way down the page
    http://www.pelicanparts.com/catalog/...ENGOIL_pg4.htm
    Didn't really want to spend $150 when just the plug is the part that's broke. Is this a necessary part for the engine to run, or is it just a part that measures oil level and trips a light in the car if oil is low? If it's not necessary I'll just skip it as I can check my oil with the dip stick anyway. Although I wouldn't want to see a light on my dash all the time. I assume if it's not plugged in it wouldnt light.
    Thanks for your help
    Andrew
  • Northern
    I like cupcakes & sh!tboxes
    • 5284
    It just measures oil level and tells you when you're a quart low.
    Considering that the M20 has a dipstick, and that E36's didn't have an oil level sensor, I think you'll be fine.
    Originally posted by priapism
    Originally posted by shameson
    • TobyB
      • 5296
      thats what the u-pull-it is for...
      t
      • E30-325iS
        • Sep 2011
        • 191
        BMW makes a cover plate if you decide to remove it. Part number 11132240942.
