2002
  • phreshkid
    • 4655
    Originally posted by peterman
    tii engine is fuel injected. if your not getting the kugelfischer pump then it wont be a good deal. check the rockers, and frame rails. new brake master cylinder probably means the old one rusted out the driver side frame rail. A new rear clip is available from walloth and nesch but not cheap.
    Nice seats tho.
    Don't worry, we have all bases covered. I was fully transparent with this car. It's surprisingly solid, with a lot of good things going for it. Will it ever be a concours car? Never. Will it be an absolutely fun and handsome car as we clean her up and get her back to stock aesthetics? No doubt about it.
    Every day we chip away at it and fix the little things. We already have donor floor pans, and those will go in soon. We are sourcing a good interior and cleaning up the engine bay of loose wiring from a previous stereo system install.
    In the engine's current configuration, it pulls very hard. That 38/38 mated to the higher compression tii block/pistons and the e12 head has a really nice balance of power. I'd be confident to say that as it is now, it will give a tii a run for it's money, and very likely beat it...not that these cars are very fast to begin with, but the torque comes on very strong with this one. I was pleasantly surprised.
    This is a good car. It's perfect for what Brad was looking for. I live around the corner so you bet I'll make sure it's done correctly.
    • peterman
      • Feb 2015
      • 173
      Originally posted by Brad Sindoni
      all panels have checked out so far with rust, pretty surprised with that actually. both front floor pans need to be replaced due to rust and the rear clip will eventually be replaced or repaired correctly. car is originally inka and will make it back to that soon. cool to have someone like ryan help me along the way.
      Look for a leaky heater box or obviously a drainage issue. If the floor pans are gone a screw driver prod test of the frame rails wouldn't hurt. If it goes through, replace/repair the rails. New pans can be had from W and N for pretty cheap. Rocker panels too.
      Looks like a project! They all are.
      Sent from my iPad using Tapatalk
      • Preyupy
        • Oct 2012
        • 73
        You need to look very carefully at those wheels, the Lancia used a 4X98mm bolt pattern and the BMW is a 4x100mm pattern. The Lancia wheels will fit over the studs but they will not be centered and the lug nuts will not seat properly and you can easily break studs.
        • phreshkid
          • 4655
          Funny that you mention that. As of now, those wheels have been mounted to the car and ran in its current configuration for over 4 years. I drove the car over 90mph and no one died, so that's a good sign.
          • Preyupy
            • Oct 2012
            • 73
            OK just an FYI. I saw a number of people in the 70's put the FIAT 124 alloy wheels on 2002's thinking they were the "factory" 2002 alloy and in the process of "Over torqueing" the wheels broke studs.
            • Brad Sindoni
              • Nov 2014
              • 178
              thanks for the heads up, i'm actually trying to source a set of stock wheels so hopefully nothing happens till then!
              _keepitgutter
              88 Alpine white Super Eta
              • 2mAn
                Señior Mod
                • 21062
                I want an 02
                Simon
                Current Cars:
                -1966 Blue Boat
                -1969 Red VW
                -1986 White BMW
                -2006 Green Thing
                Make R3V Great Again -2020
                • Brad Sindoni
                  • Nov 2014
                  • 178
                  went to triple A yesterday to put the title in my name but unfortunately since it's salvage title and title was never updated to it, i have to go to the dmv and fill out some sort of paper work and have them update the title to salvage before i can go back to triple A. they also said i will need a brake and light inspection. kind of a bummer since i will be held back more but what can you do, i hope it all gets figured out! -
                  on another note, when im driving it around and shift gears, it likes to puff out some smoke. i've been told to first check the spark plugs to see if its either running rich or lean. my first thought was that it could be excessive blow by and i would be needing to do piston rings but it's not a blueish tint to the smoke at all, it's just white smoke. will pull the plugs this morning before i head out and see if i can detect anything from that, planning on doing a full tune up anyways but i want to get this title squared away first.
                  Happy Wednesday folks!
                  _keepitgutter
                  • Brad Sindoni
                    • Nov 2014
                    • 178
                    Here are a few phone shots from the other day cruising around.
                    _keepitgutter
                    • Brad Sindoni
                      • Nov 2014
                      • 178
                      Pulled spark plugs today and I took a picture of 1 and 2. It's certain to say it's burning oil and I'm thinking maybe that's what would be causing the smoke coming out the tail pipes when I'm shifting gears. New plugs will be ordered this week forsure and they will not be ngk.
                      _keepitgutter
                      • Brad Sindoni
                        • Nov 2014
                        • 178
                        Been chipping away at this ol gal, can't thank Ryan enough for all the help and throwing me a bunch of parts. I started ripping out all the old tar insulation mats on the floor pans and will be getting the rust spots welded in with some new sheet metal in the next few weeks. Always forget to take pictures of what it looked liked before and what it looked like after since my phone is always hooked up to the aux cord playing music in the garage while I jam away but here's a few.
                        Correct steering wheel and valve cover will be going on since Ryan gave me the 3 spoke for my car and the valve cover. Still need to figure out what to do with this rear parcel shelf. The PO had some big speakers in it which I ripped out and want to get a new backing without the holes and re wrap and delete the speakers. Carpet kit and back seat delete will be going down shortly as well. Also picked this up today for the 02.
                        _keepitgutter
                        • phreshkid
                          • 4655
                          Do a valve adjustment, then come and do mine too!
                          • Brad Sindoni
                            • Nov 2014
                            • 178
                            Did some things
                            _keepitgutter
                            • Chinampa
                              • Jul 2013
                              • 247
                              I know for a fact everyone looking at this thread just checked craigslist for 2002s
                              - 90 325is
                              • Brad Sindoni
                                • Nov 2014
                                • 178
                                haha!
                                _keepitgutter
