Help Pricing E30?!?!
  • mcgillaguddy
    • 487
    Well, I likely have to sell my vert in order to help fund, and make room for, another (awesome, to be announced) project. I would appreciate some input on the value of the vehicle.
    You can see my full project thread here:
    1993 325i Convertible (She is young: 11/1992 build date)
    Schwarz 2
    Black leather sport interior
    67k original miles
    fully documented repair history from 1995 to 2015
    hardtop, less a headliner
    crack free dash
    factory option 3.73 LSD
    original radio
    A/C still works
    almost zero rust
    soft top is a good portion duct tape
    Everything in the car works, with the exception of the electric soft top (but both motors appear to work)
    crossed drilled and slotted front rotors
    The vehicle was re-VIN'd in 1994 as someone attempted to strip the VINs from the vehicle.
    Title is clean
    I don't think this car could run any better.
    What I've done in the last 30 miles (just driven to storage since finishing):
    5 speed swap (car was originally a 5 speed from the factory)
    new shaft seals
    new clutch
    new pilot bearing
    new slave cyliner
    new master cylinder
    new guibo
    lightened flywheel
    B&M SSK
    stainless clutch line
    Stance Coilovers
    Poly Subframe bushings
    Poly Rear Trailing Arm bushings
    Delrin offset Control Arm Bushings
    stainless brake lines
    New Transmission mounts (OEM)
    Poly Diff bushing
    Diff reseal
    rear seat repaired (was separating at one seam)
    new tie rod ends
    Garagistic RSM reinforcements
    New Valve cover gasket
    New fluids everywhere
    New fuel filter
    Rear Seat Headrest kit
    momo steering wheel refinished
    ZHP shift knob
    New rear brakes (crossed drilled rotors)
    Bav auto plug wires
    new spark plugs
    valve adjustment
    Repair hardtop (tree branch fell on it and put a hole in it)
    The interior is out of the car and the hardtop is awaiting paint. I would be putting the interior back in before sale. I'd be open to painting the hardtop for the buyer, leaving as is, or not including at all..
    On-going parts/expense list I've been keeping (I also have receipts for everything):
    5 spd swap - parts car
    short shift
    headrest brackets
    Momo wheel
    Momo adapter
    Stanced Coilovers - 6kg front / 9kg rear + welding
    Clutch kit - Sachs
    RTAB bushings pressed
    Upholstery Repair
    Subframe Bushings & RTABs
    BMW 5 Speed ZHP Shift Knob (E46) - Genuine BMW 251178960311
    Zero Rust Paint
    New Hardware, M8, M10, M12
    Fluids (coolant, oil, brake fluid)
    19LB injectors
    BMW Tie Rod End (E30) - Lemforder 32111126757
    Stainless Brake lines
    Rear Brakes - Crossed drilled stoptech
    Differential gasket kit
    Trunk liner set
    Rear Differential Mount - Street Compound - Powerflex
    Flywheel lightening
    Delring Offset e30 CAB - garagisitc
    Manual Trans Shift Arm Bushing - Genuine BMW 251112207071
    Clutch Master Cylinder
    Driveshaft Flex Disc/Joint; With 6 Bolt Holes for 10mm Bolts
    BMW Stainless Steel Clutch Hydraulic Hose (E30) - UUC
    BMW Clutch Slave Cylinder - FTE
    Synthetic Gear Oil 75W-90 (1 Liter) - Liqui Moly LM20482
    BMW Subframe Bolts - Genuine BMW 517181814602
    Shaft Seal - Genuine BMW 231212053421
    Flywheel Bolt; 12x28mm
    BMW Rear Shock Mount Reinforcement Set
    Red Line MTL 75W80 Gear Oil (1 Quart)
    Motul Tech Grease 300 (7 oz) - 100898
    BMW Spark Plugs - NGK ZGR5A6
    clutch fork lever
    Clutch Pipe - genuine BMW
    Output Flange Nut - Genuine BMW 232175722411
    Manual Trans Transmission Mount - genuine BMW
    BMW Oil Filter - Mann W719/15
    Clutch Pressure Plate Bolt; Plate to Flywheel; M8x16mm
    Red Line MTL 75W80 Gear Oil (1 Quart) - 50204
    Permatex Anti-Seize Lubricant (8 oz) - Permatex 800781
    BMW Valve Cover Gasket - CRP 11121730229
    BMW Inner Hex Bolt (M8X22) - Genuine BMW 333111296761
    Torx Bolt (M12X45) - Genuine BMW 230012228901
    Clutch Pilot Bearing; Sealed Type; 12x32x10mm
    A/C Drive Belt - Contitech 13X8101
    BMW Fuel Filter - Bosch 13321270038
    Selector Rod Washer - Genuine BMW 251112204394
    Manual Trans Input Shaft Seal; 35x52x7mm
    Hex Bolt (M8X100) - Genuine BMW 071199125701
    BMW Radiator Drain Plug - Behr 3767470111
    Manual Trans Output Shaft Bearing; Lock Plate for Flange Nut
    Manual Trans Shift Shaft Seal; Selector Rod Seal; 15x21x5mm
    BMW Exhaust System Hanger - 255-7661
    Self-Locking Hex Nut - Genuine BMW 071299061961
    BMW Exhaust System Hanger - CRP 182117128381$
    BMW Crank Seal Cover Gasket - Reinz 11141432240
    Manual Trans Shift Rod Clip
    Manual Trans Shifter Linkage; Dowel Pin at Shift Rod Jointhi
    Transmission Filter Gasket/Seal; O-Ring
    sssquid chip, 19lb injectors, 91 octane, m30 AFM
    Thanks in advance.
    Cheers,
    Guddy
    1988 M6 - The real project.
    1993 325i Vert - Project/Weekender
    2013 ATS 2.0T - DD
    1997 740i - sold
    1987 325is Turbo -sold
    1991 325ix - Sold
    1990 m50 325is - sold
    1987 535is - sold
  • flyboyx
    • 8371
    man, it sucks to do that much work just to sell. you are going to take it in the ass.
    as it sits, i would guess less than 4 grand. why no pics or description of interior?
    Gigitty Gigitty!!!!
    • mcgillaguddy
      • 487
      I just don't really have any photos on hand as the interior has been out of it for almost as long as I've owned it. Interior is in excellent shape. Only flaw was the rear seat, which I had professionally fixed by New England Trim in Shrewsbury, MA.
      Upholstery the day I got it back from NET:
      Steering wheel and pedals in progress photos:
      May I ask what makes you price it so low? The car is complete, very low mileage, and completely gone through.
      Thanks for the input.
      2013 ATS 2.0T - DD
      1997 740i - sold
      1991 325ix - Sold
      1987 535is - sold
      • flyboyx
        • 8371
        it appears to be a 3/4 finished project. the hardtop is very desirable, but doesn't make the car look very good with the vinyl peeled off and no headliner. how are its seals? you said the folding top is trashed?
        for what ever reason, cabrios seem to have less value than coupes unless its mtech 2. i am a cabrio guy, so i'm not basing this on my opinion. i am basing it on what i see in the market. the pool of buyers is simply more limited.
        what specifically do you mean by "almost no rust"? have you pulled the carpet up to look at the floor pans? leaky tops usually mean there is an issue there.
        also you have a minor geographic problem. since you are in the rust belt, no one from say further than a 200 mile radius will likely be interested in this car. you won't be getting calls from people in texas/georgia/california, etc. this will limit your market of buyers somewhat.
        your best bet would be to finish up the car and then sell it. you will still take it in the ass, but it is your best hope of recovering close to half of your money.
        people that spend good money on these cars don't want rust and they don't want projects.
        i'm sorry i this isn't what you want to hear, but i am trying to give you my honest opinion.
        Gigitty Gigitty!!!!
        • mcgillaguddy
          • 487
          Perfect, thanks. Just wanted to understand where you are coming from.
          I'd say the project is 100% complete mechanically (at least it's as far as I wanted it mechanically), and how far you want to take it aesthetically is open.. Carpet is pulled out right now, and there is one rust hole approx the size of golfball in the passenger side floor pan - I cleaned all the rust off it and coated it with zero rust until I could fix it. Car has had the hard top on for years, so no water issues from the bad soft top. Puttng in the interior will take me <1 hour, so I'd definitely do that before sale.
          Hardtop seals are good, and yes the soft top is trash. I'll probably end up replacing the soft top and selling it without the hardtop. Hardtop is ready for paint and I have been quoted at $300 to have it professionally sprayed. I think it's worth more not with the car though..
          2013 ATS 2.0T - DD
          1997 740i - sold
          1991 325ix - Sold
          1987 535is - sold
          • M-technik-3
            • 18946
            You are selling at the wrong part of the year. Much like most cheap motorcycle sales that happen in winter.
            Re-vin a car? That is a first for me. What is the title situation? Theft recovery/salvaged/? Odd you say it's listed now as a 94. That would be a big issue with dmv/insurance dealings.
            • mcgillaguddy
              • 487
              I don't mind waiting until spring to sell, certainly not a good time to sell a vert e30 in MA.
              Car is still listed as a 1993, but NY assigned a new VIN in 1994. Title is clear and not branded in any way. From my understanding, it was inspected by the state in 1994 and found to be harmed in no way other than a couple VINs removed (no VIN on dash, and they tried to scrape it off the doors).
              Here is the title.
              You can see the VIN listed is not typical at all. There are also VIN stickers (with the VIN shown on the title) placed all around the car next to the original VINs.
              2013 ATS 2.0T - DD
              1997 740i - sold
              1991 325ix - Sold
              1987 535is - sold
              • M-technik-3
                • 18946
                NY had issues some years back with title washing some years back? Not sure but I do know NH and RI had serious issues.
                • mcgillaguddy
                  • 487
                  Interesting.. This car was owned by the same family ever since it was re-VIN'd, so I can't imagine a problem with that.
                  2013 ATS 2.0T - DD
                  1997 740i - sold
                  1991 325ix - Sold
                  1987 535is - sold
                  • Stanley Rockafella
                    • Aug 2011
                    • 4062
                    op's probably better off parting it out
                    he's already done most of the interior disassembly
                    ijs
                    • mcgillaguddy
                      • 487
                      Part out a 99% rust free e30 with 67k miles? That sounds crazy to me.
                      Sent from my SM-N9005 using Tapatalk
                      2013 ATS 2.0T - DD
                      1997 740i - sold
                      1991 325ix - Sold
                      1987 535is - sold
                      • KingJaffeJoffer
                        • Jan 2016
                        • 25
                        I bought a vert two days ago after watching CL and Ebay for the last month or so. Not sure about Massachusetts, but within 200 miles of me (Philly, DC, Baltimore, etc.), prices of E30s were all over the place. CL ads outnumbered Ebay ones by 15:1 I bet. I would suggest setting some alerts for CL ads within 200 miles of your location and seeing what comes up and at what prices. Then, you will have a better idea when it comes time to sell it in the Spring (I'd wait until then to sell).
                        • ST1G
                          • Oct 2012
                          • 6689
                          I agree part it out!?!?!?!
                          • bostonvert
                            • Oct 2015
                            • 233
                            If you where in Belgium you could easily get 8K for this, verts are the most expensive e30's here. Mint 325 verts are going up to 15-20k..
                            The best thing would indeed be putting it back together and maybe wait until march/early spring. I'm selling my vert to but waiting for the first good weather to show up
                            Instagram : makeitsnap
                            1985 e28 520i
                            • mcgillaguddy
                              • 487
                              I'm pretty on top of the e30 scene here (Northeast USA), and I haven't found that coupes or verts have much of a value advantage - coupes do seem to appeal to more people as most people here are still building them as track/drift/whatever toys but I rarely see much of a difference in actual value.
                              Based off the prices I see on here and elsewhere, I think $8k would be a very achievable number (probably low) if I finished it off.
                              2013 ATS 2.0T - DD
                              1997 740i - sold
                              1991 325ix - Sold
                              1987 535is - sold
