Re-Using Rod bearings......
  • rcsoundn1
    • Nov 2012
    • 3361
    OK, I expect many of you to flip out about the idea of this. BUT, have any of you done this, and what was your experience like. I know its not recommended, and well as frowned upon. Here is why I ask. I have had these ongoing issues with my POS honda, and have figured out some piece of metal got into my cylinder. While I was taking the engine apart to find the source of the noise, I took the rod bearings out, thinking it was them. They are fine, and my plan is to ditch this car ASAP. I am sick of fixing it. It had a mild failed HG, and thats where this all started. Chime in please.
    • 34844
    It's a Honda - who cares? reuse them I say..
    • rcsoundn1
      • Nov 2012
      • 3361
      HAHA, I was thinking that. My father in law put a set in his jeep, did not torque them, just cranked the shit out of the bolts. I came back and torqued them and they are fine. But his were a new set
        • 34844
        as long as you didn't mix up shells/bearing caps, they should be fine. are the bolts TTY or can they be reused? that's the only real issue I can think of.
        • rcsoundn1
          • Nov 2012
          • 3361
          TBH that I am not sure of that. I am going to hope they are not. I have not read that they are anywhere
          • LJ851
            • 7919
            Agreed.
            Lorin
            The M30 is God's engine.
            • rcsoundn1
              • Nov 2012
              • 3361
              & I did keep them in order as they came out
              • rturbo 930
                • Dec 2005
                • 2627
                I reused the rod bearings in my Jetta. They looked perfect, so I figured why not.
                • rcsoundn1
                  • Nov 2012
                  • 3361
                  Out of curiosity, how many miles did they have on them?
                  • Exodus_2pt0
                    • 5943
                    No rule against it. Actually I would recommend it if nothing was changed, easier than worrying about checking clearances and dealing with possible issues.
                    I would say use a clean finger and lather them up with fresh oil before reinstall.
                    No E30 Club
                    • AndrewBird
                      The Mad Scientist
                      • 11898
                      If the torque spec on the bolts is just a number with no extra angle, they are not torque to yield and can be reused. TTY bolts will say torque to 50 ft. lbs (or whatever amount) and then turn an additional 90ยบ or something like that.
                      • rturbo 930
                        • Dec 2005
                        • 2627
                        500k. Yes, really.
                        • rcsoundn1
                          • Nov 2012
                          • 3361
                          Appears it is settled then. I shall reuse them, Thanks all
