Engine Porn
  • e30onBBSs
    • Dec 2014
    • 1347
    #61
    Drag gtr bay
    BMW tech
    Umass Amherst
    05 wrx sti
    • LateFan
      • May 2013
      • 4399
      #62
      [ATTACH]105036[/ATTACH]
      [ATTACH]105037[/ATTACH]
      [ATTACH]105038[/ATTACH]
      • LateFan
        • May 2013
        • 4399
        #63
        [ATTACH]105039[/ATTACH]
        • LateFan
          • May 2013
          • 4399
          #64
          [ATTACH]105040[/ATTACH]
          Powertech V8
          • LateFan
            • May 2013
            • 4399
            #65
            [ATTACH]105041[/ATTACH]
            [ATTACH]105042[/ATTACH]
            [ATTACH]105043[/ATTACH]
            [ATTACH]105044[/ATTACH]
            [ATTACH]105045[/ATTACH]
            • LateFan
              • May 2013
              • 4399
              #66
              Porsche Carrera 4-cam engine
              • Preyupy
                • Oct 2012
                • 73
                #67
                Porsche 4 cam Carrera engine. Each cam is 2 piece, so you have to set the timing on each lobe individually. The factory book gives 120 hours to set up the timing gears and time the cams from scratch!
                • LateFan
                  • May 2013
                  • 4399
                  #68
                  That's what I've read - they're impossible!
                  So which Porsche engine is this? No chains, gear drive?
                  • LateFan
                    • May 2013
                    • 4399
                    #69
                    [ATTACH]105229[/ATTACH]
                    • LateFan
                      • May 2013
                      • 4399
                      #70
                      Ford 427 SOHC for sale on Hemmings.
                      Fifty THOUSAND American dollars (!?)
                      http://www.hemmings.com/parts/item/1...tml?refer=home
                      • LateFan
                        • May 2013
                        • 4399
                        #71
                        Where is everybody?
                        • EyExR
                          • Jan 2011
                          • 959
                          #72
                          My 325iX DIY Threads:
                          Front Wheel Bearing Replacement
                          325iX Rear Subframe Bushings and MUCH more w/pics!
                          325iX Steering Rack Replacement, Suspension, & Oil Pan job w/pics!
                          • Delaney
                            • Jun 2013
                            • 8
                            #73
                            Give this a try out of photo bucket.
                            M49 in #25
                            • LateFan
                              • May 2013
                              • 4399
                              #74
                              Originally posted by EyExR
                              Fantastic! That's unbelievable! Can you imagine machining all those tiny little valves? And what about the passages inside a miniature carb?! Wasn't there a guy in Austria or Switzerland who built a miniature Ferrari V12? Spent years machining every single piece by hand.
                              • LateFan
                                • May 2013
                                • 4399
                                #75
                                Found him - he's French. Ferrari 312.
                                Not just the engine - the entire car made to scale by hand! Insanity! 100cc flat 12, full injected, dry sump, with 1" tall valves.
                                And the noise it makes....
