Engine outside help
  • E30randy
    • Jan 2016
    • 19
    Engine outside help
    Hey I so I have an m52 sitting outside during the winter. It's not touching the ground because it's on a tire and it has a tarp over top of it to it's not getting rained on. I frequently check to see if it is dry and it is. Is there anything I should be worried about??!
  • TobyB
    • 5287
    Us coming and stealing it...
    Condensation on the inside of the tarp can be a problem in some weather conditions.
    Mice finding a home in a cylinder, too.
    t
    • Kershaw
      • 11822
      I hope all the intake and exhaust ports are sealed.
      AWD > RWD
      • rcsoundn1
        • Nov 2012
        • 3361
        Might be a good idea to turn it over once in a while with some lube in the cycls if it is going to sit for a long time
        • marshallnoise
          • Sep 2013
          • 3148
          Believe it or not, I have that problem too here in San Diego. Granted, I am kind of coastal at less than 5 miles from the ocean. The m30 I have is sitting on a stand with a tarp over it. But it has still built up some surface rust on the block's mating surface.
          I just need to get rid of the thing for cheap, fast.
          Si vis pacem, para bellum.
          New Hawtness: 1995 540i/6 Claptrap
          Defunct too: Cirrusblau m30 Project
          Defunct (sold): Alta Vista
          79 Bronco SHTF Build
