Anyone recommend a good all in one tool set for patrolling the junkyards
  • rabbitude
    • Jan 2010
    • 247
    Im looking for a good all in one tool set for patrolling the junk yards. I have an ass ton of tools at home and have been throwing them in a backpack but I'm a bit sick of that. Id love something i could just leave in my car. Im sure you guys know all the tools i need but it would be great to have something in a somewhat compact case... Any thoughts??
    070 by wonderwilley, on Flickr
  • rcsoundn1
    • Nov 2012
    • 3361
    I have a full gear wrench set I use. I'll see if I can find a link. I added pliers and boom
    • LJ851
      • 7919
      Not possible in my opinion, you either bring a tool for every possible situation or you risk begging for the right tool when you find that diamond in the rough.
      Lorin
      The M30 is God's engine.
      • CaliDazze
        • Feb 2015
        • 193
        Me today, begging for a deep 8mm socket so I could pull some pop out windows.
        • Wschnitz
          • 8089
          Id say socket set, including the normal E30 MM sizes, 11, 13, 15, 16, 17, 19, 21, (22/23 for steering wheel?)
          T55, T50 torx, T20-40 or something reverse torx for transmission bolts.
          A couple open end MM like 17, 15, 19
          Two flatheads, two phillips.
          a thin plastic pry tool
          a wire cutter
          a BFH
          Thats it, should all fit in a carryable box. I have not even carried that much though, I usually grab the screwdriver from my toolkit in E30, the pliers, and maybe my multitool.
          willschnitz
          • CaliDazze
            • Feb 2015
            • 193
            Dont forget the 8mm!
            • flyboyx
              • 8371
              don't forget a decent size pair of channel locks. 18v sawzall
              8, 10, 13mm combination wrenches in addition to those above.
              ball joint separator perhaps.
              Gigitty Gigitty!!!!
              • e30strokr
                • 211
                12mm for exhaust bolts, 32mm or 1 1/4 inch for fanclutch, allen wrenches..
                • djjerme
                  • 5082
                  no plasma cutter?
                  2016 Ford Flex
                  • kronus
                    • Apr 2008
                    • 13032
                    my junkyard kit consists of:
                    metric wrench roll with 2x 10mm, 13mm, 17mm, 19mm wrenches and an adjustable wrench. one wrench each of 8, 9, 11, 12, 14, 15, 16, 18.
                    deep 3/8" socket rail, 10mm - 19mm, 21mm
                    shallow 3/8" socket rail, 10mm - 17mm, 19mm
                    torx 3/8" socket rail, whatever common sizes come on those
                    deep 6-10mm 1/4" sockets
                    stubby, regular and smallish flathead and phillips screwdrivers
                    channel-lock pliers
                    regular pliers
                    side cutters
                    3/8" breaker bar
                    3/8" ratchet
                    1/4" ratchet
                    rolling head pry bar
                    enough 3/8" extensions to get to the top bellhousing bolts (about 2.5')
                    have been able to remove pretty much anything I encounter and want using this kit.
                    cars beep boop
                    • ST1G
                      • Oct 2012
                      • 6689
                      My bear hands.
                      • kickinindian
                        • 2327
                        my local junkyard has an autozone down the street, the guys say everyday they sell all these tools that people forget, including me a couple times.
                        • 5Toes
                          • 9836
                          I keep my craftsman 94 piece tool kit in my car (with added extensions and snapon long flex handle ratchet and a few other specialty sockets all in the tray) and my wright wrenchs 8-22mm wrench roll. I tuck a flat head and a phillips screwdriver into the wrench roll - 95% of the tools you need for working on an E30. Total cost for something like this on sale or harbor freight equivalent is around $75 or less. I keep it behind my passenger seat and feel confident I always have a good selection of tools with me.
                          • DER E30
                            • Sep 2013
                            • 2347
                            I bring my Crapsman like 200 piece box and assorted pliers and crecent wrenches, depends on what I'm doing though.
                            -Christian
                            • Das Delfin
                              • Sep 2014
                              • 2293
                              ^ same. Most places let you go in and out to grab tools so I usually go in with 10 and 13mm sockets and a phillips screwdriver and then go back to the car where I'd have a full socket set, torx sockets, pliers, different screwdrivers, etc. I pretty much replaced my trunk tool kit with a nice craftsman socket set so I always have that with me anyway...
