M47 crankshaft question
  • fresh_TD
    • Aug 2013
    • 2457
    Normally people will shave the M47 crank nose when building an M42 stroker to fit the crank sprocket. Can the crank sprocket be milled to fit over the M47 crank nose instead? any effects by going this route? thanks in advance.
    '91 318i (Alpine) - daily
    '88 325ix (Zinno) - drive here and there!
  • AndrewBird
    The Mad Scientist
    • 11897
    I don't know anything about it, but I would assume they modify the crank because the key way would also have to be deepened, which is a lot hard on an inside bore than it is on an outside bore.
    • ccsdo5
      • Mar 2013
      • 707
      You can probably do that but you'll have to broach a new key in the sprocket, like Andrew said. I've broached a couple keys for some stuff at work on just an arbor press and it was a pain in the ass. Also would wouldn't you need to do the same for the crank pulley?
      -Dee
      5-lugged turbo 318is Barn car
      IG: @deebelmont
      • Fsnow
        • May 2015
        • 184
        There used to be a ton of info on metric mechanics site about this crank but it seems they took it all down. Is the diameter of the crank different or is the key just in the wrong location? Maybe there isnt enough material to modify the sprocket? There must be a reason that everyone does it that way but I don't know what it is
        1991 318is x 2 .
        • fresh_TD
          • Aug 2013
          • 2457
          Here's a couple of pics I took yesterday of both cranks side by dide. M42 left, M47 right. The M47 crank nose is a little bigger. I talked to a guy who did a stroker build, and said he had to mill off 0.6mm off the M47 nose to fit the M42 crank sproket.
          Sent from my SAMSUNG-SM-N910A using Tapatalk
          • Fsnow
            • May 2015
            • 184
            Boring the sprocket to fit would be easy but as said cutting existing key deeper or cutting a new keyway in a hardened sprocket is going to be a pain with a broach or shaper/slotter. So I asume the difference in location of the key don't matter? If you were really brave you could just mill .6mm off the top of the key instead... sketchy .
            1991 318is x 2 .
            • stonea
              • 2892
              Sub'd for responses. I'd love to know more about this for future ideas.
              My Garage
              Feedback
              Instagram: Stone.Hopkins
              • AndrewBird
                The Mad Scientist
                • 11897
                If it is infact .6mm off the diameter, all you would need to remove is .3mm off the key, which is only .012", not much at all. This would work.
                • fresh_TD
                  • Aug 2013
                  • 2457
                  It's more the just the key way..the nose of the m47 crank is bigger then the nose on the m42 crank
                  • AndrewBird
                    The Mad Scientist
                    • 11897
                    Right. So modify the sprocket to have a larger hole, then shave the key down so it still fits. No need to modify the crank.
                    • fresh_TD
                      • Aug 2013
                      • 2457
                      That's the plan..wanting to see if anyone has gone this route before.
                      • Fsnow
                        • May 2015
                        • 184
                        Oh yeah, woops. If it is that simple why in the hell would anyone machine the crank? I'd say go for it then
                        1991 318is x 2 .
                        • fresh_TD
                          • Aug 2013
                          • 2457
                          People have always machined the nose of the crank, because that's what everyone else before them did. It would be easier and cost less to machine the sprocket.
                          • Fsnow
                            • May 2015
                            • 184
                            Also cheaper and easier to source if the machining gets screwed up, I know which one I would rather machine. Always take the cheap/lazy/safe route if there aren't any downsides, I don't see any here yet. Keep up the good work dude
                            1991 318is x 2 .
                            • AndrewBird
                              The Mad Scientist
                              • 11897
                              An automotive machine shop could easily modify the crank, but might not have a mill to do the sprocket. Hence why people might have gone the crank route.
