tribute to the BFH
  • sticksdaman
    • Apr 2005
    • 2987
    is this e-dick measuring?
    anyway all hail BFH
    Originally posted by ebelements
    Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
    • ldsbeaker
      • Aug 2004
      • 3098
      Here you go.
      p.s. I win. ;)
      Slicktop City!
      • FredK
        • 14743
        Originally posted by Brew
        ...with the right techniques (such as using an impact driver on rotor set screws- I've never stripped a rotor set screw) you almost never need to use a sledge hammer working on your car.
        Ah, but what man-made implement are you using to hit the back end of the impact driver? HAHAHA. HA. HA. :p
        Oh, never mind, you use a 6 oz geologist's hammer to hit the impact driver. ;-) Or for really stubborn set screws, a 10oz ball peen hammer. :grin: OK, fine, you don't use a sledge to hit the impact driver, but you do need to hit it using a decent sized hammer.
        Ya know it could be worse. There could be tales of hitting a ratchet with a BFH, or tales of putting a 4 ft cheater bar on a ratchet. THAT would be a travesty.
        • beamR X
          • Apr 2006
          • 145
          Ha, ha, ha! So true!!!
          How about hiting the end of a 5 ft pipe used as a cheater on the end of the 1/2 drive ratchet with a BFH?
          :blowup:
          RIP ratchet! Long live lifetime warranty!!!
          (.Y.) R cool.
          Falco rocks!
          • beamR X
            • Apr 2006
            • 145
            Originally posted by ldsbeaker
            Here you go.
            p.s. I win. ;)
            That's scarry!
            I bet you can feel all your joints vibrating from your pinky finger to your shoulder when utalizing that fine piece of toolary!
            (.Y.) R cool.
            Falco rocks!
            • kencopperwheat
              King of Kegstands
              • 14396
              Originally posted by nando
              those hammers are weak.. I love using my 10lb sledgehammer! :D
              10? pshhh. I use my 30 with the 36" fg handle :)
              Originally posted by Gruelius
              • FredK
                • 14743
                I do too, but only to tighten the oil drain plug and while installing 86 mm pistons into a 84 mm bore. :crazy:
                • chuckybob
                  • Aug 2004
                  • 952
                  been there and done that. ratchet lived, nut was loosened. all in a day's work.
                  : : 1984 318i : : PNW E30 Crew : : Sold!!
                  Now becoming the R3vlimited Pro3 car
                  http://www.r3vlimited.com/board/showthread.php?t=93780
                  • NC325iC
                    • Mar 2004
                    • 6565
                    who doesnt use a hammer on a ratchet... thats what you do when you have a hammer and ratchet close at hand and the breaker bar's on the other side of the car
                    • ldsbeaker
                      • Aug 2004
                      • 3098
                      ^^ word.
                      Slicktop City!
                      • Axxe
                        • Aug 2004
                        • 3355
                        12oz and 20 oz work well for me, 4lber comes out in dire situations. I've used a 8' pipe on a breaker bar before, fucking sheared the 1/2" drive square right off the knuckle!! Then the heat came out. That's my new BFH.
                        Keep it slideways!!
