How far should bolts go through block when on engine stand?
  • jayuuey
    • 414
    I mounted a 24v motor to an engine stand getting it ready for a swap. Currently my bolts (90mm) are just flush with the tranny holes in the block. Is this good to go or should they be a little longer? Also, are washers recommended where the stand mounts to the block or is that only a concern for aluminum blocks?
    Thanks.
    Sent from my VS985 4G using Tapatalk
  • TobyB
    • 5218
    You're good.
    You can't go farther than all the way...
    t
    • AndrewBird
      The Mad Scientist
      • 11898
      Over 75% of the load on a bolt is taken up by the first 3 threads, so you are good to go.
      • ELVA164
        • 4861
        I always use washers just for security, never hurts to spread out the load a bit on the surface. Here's a good visualization of the load on particular bolt threads:
        • rturbo 930
          • Dec 2005
          • 2615
          If you're all the way through the block, you're good. I mean... can't really improve on that.
          • ELVA164
            • 4861
            You could weld on a bung, add a few gussets, maybe create an elaborate truss...
            :D
            • TimeMachinE30
              • Jun 2014
              • 3749
              :D
              :devil: kind of what I was thinking... a flying butress.
              ACS S3 Build / Dinan 5 E34
              • Matt-B
                The Waffler
                • 3856
                Originally posted by TobyB
                You're good.
                t
                Amen brother
                • jayuuey
                  • 414
                  Too funny. Thanks for the comments, especially the load visual... and jokes.
