What's the deal with the E30 turn signal relay?
  • ELVA164
    • 4861
    I don't think this counts as technical so I posted here, but tow if needed.
    I noticed this back when I had my 2002. The turn signal in that car (and basically any other car) flashes evenly right away. The E30 flasher relay is different for some reason. When you first depress the turn signal stalk, the light stays on for 0.5 second. After that first flash, the relay clicks every 0.25 second.
    Why is the first click twice as long as the others? It happens in every E30 I've driven.
  • earthwormjim
    • Jul 2014
    • 434
    Probably going past the click point on the turn stalk resets the flash interval. When you're pulling the stalk down or up, before the click point, the turn signal is activated, then as you transition over the click point, the interval is probably being reset, but it happens so fast the light never goes out.
    • 2mAn
      SeƱior Mod
      • 20954
      your turn signals work?
      Simon
      Current Cars:
      -1966 Blue Boat
      -1969 Red VW
      -1986 White BMW
      -2006 Green Thing
      Make R3V Great Again -2020
      • ELVA164
        • 4861
        If I understand what you're saying, that's not it. You can hold the stalk at the point where the relay is first activated and it will still wait the 0.5 second.
        • ELVA164
          • 4861
          Nothing, huh?
          • reelizmpro
            • 9552
            Not sure what you're talking about. How about a video?
            Are you saying the blinkers are fast? or are you just complaining about the light turning on first before flashing? Typically it does that when there's a resistance problem like bad contacts or copper based bulbs.
            88 M3 - LACHSSILBER
            89 M3 - ALPINEWEISS II
            • ELVA164
              • 4861
              Sure, I can do that!
              • ELVA164
                • 4861
                Here's the link, since I still don't know how to embed with Flickr:
                https://flic.kr/p/WBufMF
                • reelizmpro
                  • 9552
                  Looks normal to me
                  88 M3 - LACHSSILBER
                  • Das Delfin
                    • Sep 2014
                    • 2293
                    I've noticed it too. I like it because I can change lanes with only one blink ;)
                    • Javier h
                      • Sep 2007
                      • 1189
                      Yup
                      Its delayed compare to the others. I have to look at my car and see the timing sequence. I never really noticed but I suspect you might be correct. The intervals you would think, would be the same.
                      • IceWhite
                        • Jan 2015
                        • 945
                        Functions exactly as mine.
                        1990 325i
                        2004 330i Individual 6-speed
                        • ELVA164
                          • 4861
                          I'm not questioning whether or not it's unusual for an E30; I know it's normal, every E30 I've driven is this way.
                          My question is why is the first flash twice as long as the others? And if someone knows that answer, maybe I can find a way to make it...not twice as long as the others.
                          • lukeADE335i
                            • Apr 2013
                            • 1389
                            Seems pretty OCD to me... if that's how they all are, what is the point of working out how to shorten the first flash of your indicators by 0.25 of a second?
                            My e30: OEM+ with M30B35
                            • ELVA164
                              • 4861
                              Because I'm curious why it's different? That's really it.
