Poppin & Snappin
  • SickE30
    • 769
    Poppin & Snappin
    Hey guys. Past couple of days I have been hearing a popping from the right rear of the car. when I am turning right and accelerating it is really loud. Also @ highway speeds my shifter is shaking. Blown axel? Help me out. Thanks.
  • Werksmini
    • 1658
    That seems right, it happened to my friend wile doing donuts (FWD) If you put loads on axles they break.
    Correct me if im wrong.
    I bombed Korea every night.
    • bkelsey86
      • 1173
      probably busted ur CV joints...............
      • AdamF 88iS
        • 2051
        BMWs never have axle problems. I'm talking 99.99999% chance its a wheel bearing or the differential before it's the axle.
        You guys are right, the symptoms you describe could be the axle...but very unlikely.
        Adam Fogg- '88 M3
        Common sense- It's the new 'gifted'
          • 34847
          that's not true. if your CV boots tear or rip open and your CV joints get dirty or overheat, they can go bad. they can also go bad from being stressed or operated at funny angles.
          • Spaz
            Crazy Canuck
            • 2276
            ix are the only e30s that experince funny operating angles, and thats only in the front. the rears only move up and down, VERY rarely that you see a bad one, the only time you will, is as nando said, when you have a torn boot, causing dirt and muck to screw it up.
            Cam .W '91 325is
            Spaz's 1991 Alpine White???? S52 Build Thread...
            • Spoon e30
              • Jan 2004
              • 165
              my car is doing almost the same thing, but mine is on the left rear tire. It only makes noise on right turns. i'm guessing diff, so i'm swapping my open 4.10 with a 3.91ls for now. Who know's, I may end up liking the 3.91.
              • YAN-3
                • Jan 2004
                • 6018
                about a year ago on the high way coming off of an on ramp some how my fricking axle got bent and ripped right from the differential my right rear axle
                • E30godz
                  • 1524
                  wow
                  • Spoon e30
                    • Jan 2004
                    • 165
                    yeah, i put in a 3.91 ls diff in tonight :twisted: , and still have the sound, so i'll check the cv joints tomorrow
                    • mikeedler
                      • 6707
                      a trick that i learned from a german is to lift the car up off the ground on both sides and start it up and run it in gear for a while. He told me that especially when the car is lowered the grease tends to fly out of the joint, because of the angle like some of you said. I tried this and it worked on my car. It is a very cheap way to fix it(costs nothing) and a very easy starting place. If not that I would say a cv joint has failed if its making a clicking sound. I have blown a couple of half shafts apart doing hole shots, the cars dont seem to like that kinda abuse too much!
                      • LennysEleven
                        • Mar 2004
                        • 163
                        Are you saying that just running it in gear, jacked up may fix the problem?
                        How does that help?
                        thanks
                        Nick
                        • BahnE30
                          • 1050
                          i think he's trying to say that if it's lowered that the grease may not be right were it should be so raise the rear of the car and put it in gear and let it run awhile to get the grease somewheres back to normal
                          could be it but i'm doubtful
                          feel free to correct me if i am wrong though
