E21 engine bay wire question
  • mr.vang
    • 4371
    I know this is an e30 forum but I'm sure some of you guys have owned an e21 in the past, so I could use your help.
    I just bought my first e21 and found this wire hanging lose around the alternator area. Look like the previous owner cut the wire and clamp in a small gauge wire to the end. The car start and is running great, so I'm stumped where it should be hook up to.
    Thanks in advance.
    Sent from my SM-J700T using Tapatalk
  • Stanley Rockafella
    • Aug 2011
    • 4060
    something aftermarket?
    • mr.vang
      • 4371
      Yes, by the look of it, it was cut and wrapped in black electric tape. You can see the contrast between the gray and electric tape.
      • kickinindian
        • 2327
        either an aftermarket alarm that maybe was controlling the alternator or maybe an oil pressure switch that broke off the block?
        • TobyB
          • 5251
          in the past
          What is this 'past' you speak of???
          Given that it's coming out of a factory harness, are you sure it's not the charge
          light/exciter for the alternator? What's the color(S) before the buttheadsplice?
          I can look under the hood of mine tomorrow...
          t
          • pandaboo911
            • 2070
            Blue is alternator Field wire. Check that you’re getting 13-14v while running
