numbers on the block hartge h26
  • 2002jm
    • Sep 2005
    • 2068
    Some one from Poland is asking about the numbers on my hartge engine.
    I see a large 2.7 on the block and 17140 H-26 hartge on the head. Also,
    the head has the number 84 with arrows in a circle around the 84.
    My question is: This is a 323 euro car. Is it possible Hartge put a 2.7 block in
    this car along with all their other upgrades? Would this be a stroker motor?
    thanks for any help,
    jm
  • TobyB
    • 5224
    This is where pictures tell a thousand words...
    your head was cast in (however many dots are showing = month) 1984.
    the 2.7 cast into the block may mean it was an eta block- or not.
    The machining that is done to the casting after it cools defines what it really is.
    And it doesn't tell you what crank is in it. It's just a casting number that
    identifies what casting was used. And if you find the date code, approximately
    when it was cast.
    t
    • 2002jm
      • Sep 2005
      • 2068
      when it was cast.
      t
      Sounds like I would have take the engine apart to really know.:)
      thanks for the reply,
      jm
      • e30m3s54turbo
        • Jun 2010
        • 3246
        Hi John.
        Hartge would stamp their motors on heads. On my old 1984 Hartge H26 said Hartge H26 on head. On old Hartge would have BMW vin tag. My was original 323i. The Hartge cars H23,H26 and H27 would not have the Hartge red vin tag. Only the H28, H35 and H35-24. The last 4 Hartge H35-24 e30 m3 blue Hartge vin tags.
        • roguetoaster
          Biggus Tippus
          • 7829
          Concur, the only Hartge marking on the engine itself of my H5S was on the head.
          • 2002jm
            • Sep 2005
            • 2068
            thnaks
            Thanks for the replies: My head has the h26 hartge stamped on it, but I am also wondering
            if the 2.7 on the block would mean a possible stroker motor. My old 82 323i had 2.3 on the block.
            thanks,
            jm
            • 2mAn
              SeƱior Mod
              • 20542
              Maybe Im wrong, but I thought the 2.3 casting meant 80mm Bore, whereas the 2.7 meant 84mm Bore
              Simon
              Current Cars:
              -1966 Lotus Elan
              -1986 German Car
              -2006 Volkswagen Jetta TDI
              Make R3V Great Again -2020
              • 2002jm
                • Sep 2005
                • 2068
                think you are right
                I was thinking hartge took the block out and put a 2.7 in. What would be the reason if they were not going to build a stoker motor...the internet information says they did this with the h26, but who knows without taking it all apart.
                thanks,
                jm
                • djjerme
                  • 5082
                  2.7 was on the B27 and B25. Not sure though about the first year "528" that BMW put in the E28's. It was the High Compression motor that was like a one year thing.. Could Hartge have grabbed those blocks as well?
                  That's where it's easier with Alpina since they stamped both the head AND the block.
                  2016 Ford Flex
                  • 2002jm
                    • Sep 2005
                    • 2068
                    that would be great
                    I wish it was a hc motor:).
                    Sad but hartge did not keep records and Kohl has not replied yet to other questions about this car they built.
                    thanks for the replies; who knows; can't take it apart to check the motor:)
                    jm
                    • e30sh
                      • Apr 2015
                      • 618
                      What's the build date on the block. It's right above the starter near where the block meets the head. Uses the day / month / year format. If it was made after the build date of the car, you will know if it's been swapped.
                      You can borrow a borescope or even buy one for an iphone. Peek in from the drain plug. 2.7's had an "81" for the 81mm stroke cast into the crank.
                      • 2002jm
                        • Sep 2005
                        • 2068
                        thanks,
                        Will check the dates on the block in the morning.
                        jm
