How can i free up a few more ponies for my 86 325?
  • vic_325
    • 264
    i have a stock 325 and want to know what i can do to get a few extra horse power?
    thanks- Vic
  • RobertK
    Kicked cancer's ASS.
    • Jun 2005
    • 5864
    Assuming that it's an eta I would say get a JC Chip for it (or MarkD if he makes an eta chip).
    From what I've been told that driving an eta before and after a chip upgrade the difference is like night and day.
    • Mike325
      • Mar 2006
      • 3685
      You are correct. I have an 87 eta with the turner chip and it is very nice:D
      Originally posted by Kershaw
      • Jand3rson
        • 37587
        Seconded. The Jim C chip in my car was the best money I've spent on my car yet. Turns an eta into a much more powerful engine.
        • vic_325
          • 264
          noobie question, eta an engine spec or what?
          • mattdk318i
            • Jun 2006
            • 3953
            ive heard of a flywheel upgrade helping. Since the eta flywheels weigh a ton.
            • E30 Wagen
              Also, an 'i' exhaust swap, and 'i' intake swap. Don't know what kind of hp you'll gain, but I've heard swapping these 'i' components frees things up. Or, you can go further and drop in an 'i' camshaft (requires machining of the head for oil journals) and 'i' valve springs, and i think motronic 1.3.
              • SpunkyE30nOk
                • Jun 2006
                • 228
                chip, cat delete, not sure if a 027 afm on an eta works but maybe, 19lb injectors and custom exhaust...the piping on the i and eta motors are different it won't just bolt up
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  "eta" is the e in 325e. 325's came in two different models, the i and the e. Basically the i is the more sporty version of the 325 while the e is the economy, better gas mileage version. The only difference in the two is the motor. The i came with a higher revving, higher compression 2.5L with more HP and less torque while the e came with a low revving, lower compression 2.7L motor with less HP and more torque. The i motor is the M20B25 and the e is the M20B27.
                  Look here for a little more info:
                  You can also search on this topic and come up with lots of info.
                  The FAQ subforum is also a great place to start.
                  • vic_325
                    • 264
                    thanks alot guys
                    -Vic
                    • moatilliatta
                      • 6151
                      them 19 pound mustang injecters will not work. as for they are hi impedance and the motronic on eta's work with low impedance injecters.
                      @Zakspeed_US
                      • AndrewBird
                        The Mad Scientist
                        • 11898
                        You can use e28 M5 injectors IIRC.
