ICV removal/bypass?
  • O 16581 72452 5
    • 1066
    ICV removal/bypass?
    Can't find anything searching, figure i'll ask before i waste money on plugs and stuff to cork the open lines that i'll have from removing this. On some cars, i know it's possible to remove this without any issues, wondering if it's possible on these cars. Probably have to leave the unit in there with the wires connected to avoid a CEL i'm assuming?
    Car idles crappy and runs like absolute shit when cold and intermittantly runs bad after warmed up, figure i'll start at the cheap/free shit before moving to the AFM, O2, etc.
  • Mike325
    • Mar 2006
    • 3685
    Do you mean remove it for diag purposes or to get 100% rid of it?
    Originally posted by Kershaw
    • O 16581 72452 5
      • 1066
      Just ditch it.
      • MrK
        • Jan 2006
        • 709
        If you think your car idles like crap now, ditch it and see how much worse it'll get, if you can get it to idle at all :D
        AFM flappers are notoriously horrible at keeping a smooth idle without an ICV.
        This is your M20 on steroids:
        • O 16581 72452 5
          • 1066
          I see, the car i removed one on was MAP.
          • redbull 325is
            • 7471
            clean the ICV witha tooth brush and some simple green.. works everytime for me.
            Build Threads:
            • Digitalwave
              is a poseur
              • 6298
              Instead of fixing it you just want to throw it away? Nice.
              RISING EDGE
              • O 16581 72452 5
                • 1066
                Don't see why not if the car runs fine without one. Like stated before, i blocked off one on one of my cars and the idle was better than ever.
                • Mike325
                  • Mar 2006
                  • 3685
                  Idle controle valve. I don't see how it could have a controled idle without this part.
                  • Axxe
                    • Aug 2004
                    • 3355
                    I've heard of some M20's running around with it bypassed, and a simple manual valve replaced. Never seen one though, so can't give any insight other than my guesstimate of it being a ball valve from home depot or something along those lines. The same source told me that they are used on race-cammed M20's, just set the idle a bit higher with it, the ICV can't manage the aggressive cam anyway.
                    Keep it slideways!!
                    • Grimm862
                      • Jun 2006
                      • 215
                      The car will idle without a ICV. My friend had a 86 325 and just plugged up the 2 hoses and it worked fine. Just had to warm up a bit for it to idle good.
                      • equate975
                        • Jun 2004
                        • 3382
                        I have heard of people bypassing it then turning the throttle adjustment screw up a ways to compensate for it.
                        Rollin' with a Geistkuchen
                        • MrK
                          • Jan 2006
                          • 709
                          That's funny, my ICV is 'managing' my race cam just fine
                          I still don't see a plausible reason for just eliminating it. BMW put it there for a reason no?
                          • euroshark
                            • Apr 2006
                            • 3491
                            You CAN rig the ICM safely and it will only effect the idle when the motor is cold. This is an old trick I learned from the 5 series community. You drill a ~5.2mm hole in the center of a penny, and attach the penny to the outlet side of the ICV with silicone, duct tape, epoxy (the strongest probably) or a combo of the three. Reattach the rubber hose, unplug the ICV and bam! Perfect idle speed. You might have to help it warm up for the first 30 seconds to a minute with your foot, but after that it's usually ok. I did this in my 533i for two months and never had any trouble!! I've got a picture if you want.
                            • O 16581 72452 5
                              • 1066
                              Cool, thanks alot, that's what i wanted to hear.
