$2 of diesel to help clean the motor????
  • LINUS
    • 2422
    #31
    Originally posted by 1991 318is
    Fuel injector cleaners (Techron, STP, etc.) are 65-90% kerosene and the rest is Stoddard Solvent (paint thinner/old time dry cleaning fluid) which is why they don't list the ingredients. Kerosene is cleaner than diesel and just a few cents more per gallon - $2.75. That much Techron is $40. Techron has some other high end solvents in very small quantities but none of the others have much else..
    I generally stay out of 'snake oil' threads, but this post is pretty close to what I know is practice by a local shop where the tech is ex - Lexus, so I take my Landcruiser to him for advice since Lexus LX450==Toyota Landcruiser. One practice in particular is to add 3 cups mineral spirit solvent to 5 gallons gas, it helps plump up older rubber o-rings and seals, and has a mild detergent effect on injectors.
    That's the only one he really uses, but he'd seen another mechanic stick straight acetone in a crankcase, run for 20 mins, and drain the oil and change. I don't know the quantity used, but I wouldn't guess much more than a cup if it was a 5 quart oil system. He said that worked for freeing sticky lifters.
    As a cocktail, since I was in the refineries, I'd get one of my friends research grade toluene which is 120 octane, and what they run in the test motors in the refineries to get the final octane value of gas blends they send out. He used it in his wifes' v-tec Prelude since she was running it down at SIR.
    I now use the following toluene formula where, since I no longer am in the refineries, have to use standard grade which is 114 octane.
    So since toluene is 114 octane, use this to figure what octane you get:
    ( Gallons_of_gas * Octane_of_gas ) + ( Gallons_of_toluene * 114 )
    __________________________________________________ _
    Total Gallons
    Toluene isn't as cheap as it used to be, but still cheaper than buying retail high octane gas. Roughly $8.50/gallon a few months ago.
    I used to get to 100 octane and run my old Corrado on that from time to time, and I'd stick a cup or mineral spirits in too, used to really wake up that VR6.
    It seems like anything over 100 was overkill, since you never had the knock sensor retard the timing, that being my goal with the Corrado. Same thing though with my old YZ250 dirt bike, and my current YFZ450 quad. My BMW never got the toluene treatment when it had the S14, so I don't know what benefit would come from it there.
    Something I personally did when I got my Landcruiser was to pop the plugs and I put ~1.5 ounces of 2/3 mineral spirits / 1/3 laquer thinner in each chamber, let sit overnight, and fired it up and ran for 15 minutes. I did this 2 more times and got quite a bit of laid down carbon off my pistons. After the 3rd time I changed my oil to be on the safe side, since I'm sure some got past the rings. Worked quite well, I borrowed a bore scope and was able to see almost all but a really thin layer had broken up and blew out.
    Another mechanic I trust who was a lead mechanic for a Saab & Porsche dealership, and raced Viggen(SP?) Saabs, said a whole bottle of Redline fuel system cleaner in 5 gallons super unleaded does a lot of good, despite the Redline bottle saying to add a full bottle to a 20 gallon tank of gas.
    Funny sidenote, we used to get those fuel system additives (Techron, Clean System 5, whatever Shell called theirs too) in 4' x 4' x 3' plastic totes, maybe 200-300 gallons. That stuff in pure form was very corrosive to all but the stainless ball valve & teflon gasket. Anything else in constant contact was in pretty poor condition down there. I thought it was funny.
    It's not how you handle the good times, but the faith you keep in the bad that defines you.
    • Jscotty
      • Jan 2007
      • 2285
      #32
      Ok. That settles it. I am going to the auction next week and I am going to get the cheapest crappiest beater that I can find and use that for experimental purposes.
      • dmgt500
        • Feb 2007
        • 2
        #33
        if you want to clean your engine, they sell product to do so. Can;t remember the name off hand but its only a few bucks and it works pretty well. It comes in a metal can like the old oil cans. Ran it through my 325is and it cleaned the valve train up real nice. Have to do it a couple time though for best results.
        • euroshark
          • Apr 2006
          • 3491
          #34
          Seafoam.
          Seafoam?!
          Yes, fucking Seafoam!
          The end.
          • eyagel
            • Jan 2007
            • 756
            #35
            :rofl:
            • LINUS
              • 2422
              #36
              Originally posted by euroshark
              Seafoam.
              Seafoam?!
              The end.
              Sorry man, seafoam is crap. I used to work the used car lots as a kid in college - we tried that stuff plenty. If you have to resort to seafoam just dump a cup of acetone in the crankcase. Major ingredient in "Motor - Prrrr", and that stuff worked waaaay more than seafoam on hydraulic lifters
              • euroshark
                • Apr 2006
                • 3491
                #37
                Interesting... but we don't have hydraulic lifters...
                After half a can of the shit in my gas and half in my oil, visually, it is 500x cleaner than before under the valve cover, and my idle smoothed out within the first few miles. I'm sure it can be hit or miss in some applications, but I like it!
