Broke My Timing Belt :curse:
  • vic_325
    • 264
    i let my eta warm up like always, when i put it into second gear, the engine shuts down and i hear chattering noises. i wasnt going fast at all revs were maybe 1000-1500. i started working on it took off the timing belt casing and everything else in the front of the engine. could it be possible that nothing in the head is broken?
    Thanks, Victor
  • delatlanta1281
    Dart Master
    • Mar 2006
    • 10317
    oooooo that sucks. you wer just sitting there?
    Yours truly,
    Rich
    you kids get off my lawn.....
    • vic_325
      • 264
      yeah, reved engine in first till 2k, then put in 2nd let the clutch go gave some gas, and it just gave up, 50 feet the drive way lol
        • 37832
        I'd say it's possible that no major harm was done. Personally I would pull the head to be sure.
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
        • MikeK
          • Jan 2005
          • 2771
          and plus, eta heads are cheap :)
          Toyota Pickup
          • MikeE30325i
            • 2356
            Thanks, Victor
            damn you let it warm up? you musta been extremely unlucky, sorry to say. i never let my car warm up before i will drop the clutch. *crosses fingers* it wont happen to me hopefully. i still havent been able to blow up my eta.
            • YAN-3
              • Jan 2004
              • 6018
              sorry to hear that bro
              • jmarch
                • Oct 2004
                • 163
                Look on the bright side, this is your chance to upgrade to "I" specs.
                1995 Porsche 993 6 speed
                2001 BMW M3 6 speed - DD
                2001 BMW 530iA Sport - Hers
                2005 KTM 450EXC 6 speed
                Gone:
                1988 BMW M3 2.5 EVOIII Clone
                1988 BMW 325is x2
                1985 BMW M635CSI 286hp
                2001 KTM 400MXC
                • MikeE30325i
                  • 2356
                  nothing truer than that.
                  • mrsleeve
                    • Mar 2005
                    • 16386
                    yeah you gots bent valves change the head.
                    Originally posted by Fusion
                    William Pitt-
                    • e30devo
                      • Aug 2005
                      • 1102
                      its possible but you said yourself you heard chattering noises. i would do a quick timing belt swap and see if she runs before pulling the head. just me though.
                      • backtrail69
                        • Jul 2005
                        • 4471
                        I would just swap in a full i motor... they really arent expensive at all...
                        :: PNW Crew ::
                        '87 325 4dr, '74 2002
                        • bimmer8604
                          • 3017
                          pulling the head isn't too difficult. you've already drained the cooling system, the next hardest part would be unbolting the exhaust manifold and pulling the head(leave the intake manifold on, much easier)
                          I would pull the head. The motor is an interference motor, which means 99.9999% you've damaged something. it may not be too severe, and it may work itself out, but if you want the car to run normally you'll need to fix whats broke.
                          How many miles are on your car? If you are going to rebuild your head(new seals,valve guides, valves etc) then you might want to think about freshening up your bottom end. I recently just put a fully rebuilt head(new cam, rockers, everything) and a few weeks later sucked out my rings. The car when cold smokes worse than an old Honda. But if its just a DD beater, slap some used valves in there and call it good.
                          Kyle
                          1988 M3, 97 840, 99 XJ
                          DILLIGAF
                          • Digitalwave
                            is a poseur
                            • 6299
                            Crack open the valve cover, it should be pretty easy to tell if you broke anything.
                            And warming up the engine doesn't have anything to do with a timing belt breaking.
                            RISING EDGE
                            • vic_325
                              • 264
                              thanks for the info guys, i pulled the valve cover and nothing seems broken,
                              while im in there im changing the thermostat, waterpump, all the other belts and distributor cap & rotor. im just going to throw everything back on and hope for the best,
                              but my problem is figuring out how to get the crankshaft / camshaft/ distributor all lined up
                              does anyone know how to get everthing in their right place?
                              thanks
