Mixing Oil
  • threlevenguy
    • Dec 2006
    • 1057
    Mixing Oil
    i had some 5w40 synthetic in my car and then i got really low so i added all i had..pennzoil 10w40. is that really bad to mix them? do i need to drain it all out?
  • Jscotty
    • Jan 2007
    • 2285
    No not really.. Although its not adviseable to mix up the oil on purpose, if you were simply topping of the level there is nothing to be concerned about. The only time you really need to be concerned is if you live in a climate that has extreme temperatures because the odd quart will affect the performance of the rest of the oil. Like if you were running with 5-30 or 0-30 because you lived in the upper midwest and then you put a quart of 10-40 in it you have made the oil slightly thicker.
    • backtrail69
      • Jul 2005
      • 4471
      Id do an oil change the next time you get a chance. Not a big deal for short term use.
      :: PNW Crew ::
      '87 325 4dr, '74 2002
        • 37833
        Regardless of the mixing thing, you shouldn't use Penzoil! :)
        Grover Beach, California
        BimmerHeads.com
        • reelizmpro
          • 9558
          It's fine...nothing to worry about with those viscosities.
          88 M3 - LACHSSILBER
          89 M3 - ALPINEWEISS II
          • Kruzen
            • Mar 2004
            • 5603
            Castrol GTX dino oil ftw!
            Who doesn't love a little BBQ?
            Griot's Garage at a Deep Discount
            • smooth
              • Apr 2005
              • 1940
              it's not the viscosity I'd be concerned about, am I reading you right in that you mixed regular (dino) oil with synthetic?
              Das ist nicht nur nicht richtig, es ist nicht einmal falsch!
              • Pedro
                • 965
                yeah he typed it out that way. so did you?
                http://www.volkswagenjettacup.com/
                • threlevenguy
                  • Dec 2006
                  • 1057
                  yea i mixed synthetic and regular(? i guess) its all i had at the time i was reeally low. better mixed than none?
