Dyno Results +VIDEO
  • matt325is
    • 409
    Dyno Results +VIDEO
    Well, it was time to dyno the car. I got it running rich enough so I could drive 70 miles to Carb Connection in Kirkland, WA. The drive up was great, no problems. Get there and strap it down.
    First light loads were very rich, just tuned those down in realtime as Nels controlled the throttle. Only did this for low rpm.
    First real dyno runs, under normal load, was tuning from around 1000 rpm, and just tuned it up and down, while looking up at the Wide Band o2 sensor they had hooked up. These went very well up to 3700rpm.
    Then we found out the clutch was slipping. This was a major setback, I could only put power to the rear wheels until 3700rpm. Considering this, these numbers are VERY good.
    Results, 191.6 hp at the wheels, and 272.3 tq at the wheels at only 3700 RPM. This converts to approx 230hp at the crank and 327 ft.lb. tq at the crank, at 3700RPM.
    The guys there at the dyno said it its going to make a LOT of hp at the wheels, probably 300+ as an estimate.
    This graph is of my non turbo run (a few months back) and my turbo run. The Non turbo run is in red, and the turbo run is in blue. The torque figure is the higher one.
    Here is the graph
    Questions/Comments?
    I also got some vid that i might post up, it sounds SICK.
    By the way, does anybody know of a good place to buy racing clutches? I know Ireland has them, and so does Bekker's, Ireland only has the disc though, anybody know of a good pressure plate? thanks
    UPDATE
    Video
    RIGHT CLICK-> SAVE TARGET AS!
    matt
  • Digitalwave
    is a poseur
    • 6300
    Wow.
    RISING EDGE
    • e30evolution
      West Werks
      • 1888
      get a new clutch.... graph is looking good.... that would be dope if you got 300 hp to the wheels... let me know next time you go to dyno it, and i will be there
      http://www.westwerksauto.com
      • m42technic
        • 1056
        :shock: Very nice numbers.
        James Peacock
        WWFSMD?
        • theberglar
          • 143
          :shock:
          Very nice.
          Does anyone have the article (that was on e30sport) of how he rebuilt the M20?
          • BS87
            • 1606
            *looks at torque*...... *drools* :twisted:
            • Nick325is
              • 1409
              Wow :shock:
              • diegom6
                • 4447
                Damm you Matt!! those are impressive numbers just at 3700, how much press are you running?
                Damm can't wait to get a bigger turbo or trim and put 15 PSI at my bimmer...
                By the way, I installed the Vortech FMU= Results=?
                -No more Pinging in third gear or higher gears and speed
                -Runs rich all the entire range or RPMs... up to 6500, before in the top rpms was runing lean...
                Conclusions? Great Upgrade....we will see how much can handle the double of fuel press now with the Vortech FMU the injectors...
                PD: Matt, where did you relocate the oil cooler? anyt pics? :P
                Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
                • CobraKai
                  • 1544
                  Wowie wow wow wow. :shock:
                  -alex
                  i take pictures.
                  • e9nine
                    • 1890
                    I think its appropriate to assign the torquemeister title to you! Get a new clutch already :P
                    • Bryson
                      • 1490
                      Sweet lord, that's amazing.
                      What's the total on money invested?
                      • Streetspec_iS
                        • 1622
                        thats just farkin nutty! good work matt! wow :up:
                        sigpicM42 Brigade ... Throwing craze in the 318
                        • rwh11385
                          lance_entities
                          • 18403
                          WOW, you're car sounds like a friggin plane..... must fly like one too :shock: damn...... get that clutch tho.....and get ready for take off
                          • Digitalwave
                            is a poseur
                            • 6300
                            I think that might be the dyno spooling down.
                            RISING EDGE
                            • Jon325i
                              • 6934
                              Very impressive results Matt. That turbo whine sounds sick as hell :up:
                              Jon
                              Rides...
                              1991 325i - sold :(
                              2004 2WD Frontier King Cab
                              RIP #17 Jules Bianchi
