Subframe Carnage!!!
  • Funkmasta
    • May 2004
    • 7185
    Subframe Carnage!!!
    Pulled out my subframe this morning from the 335. it was worse than I thought it was...
    check this out:
    ick.
    Joe Funk -- Portland Oregon
    That Guy.
    03 X5. 3 liter obviously.
  • Funkmasta
    • May 2004
    • 7185
    the two bolts on the drivers side backed out slightly over 5k miles, then the mounts on the passenger side just ripped the metal like it was nothing.
    That Guy.
    • mode
      • Jun 2007
      • 140
      The same thing will happen if you have an I engine, and a 2.79 diff.
      • 86espowa
        • Jun 2007
        • 296
        i have a subframe that has damage like that.........
        Time to replace it!
        • Funkmasta
          • May 2004
          • 7185
          Time to replace it!
          literally over the course of 24 hours it went from totally driveable with no symptoms to fully framer-ed.
          That Guy.
          • 86espowa
            • Jun 2007
            • 296
            yeah, i know what you mean. extreme vibrations in first gear giving it some gas. scared me when it happened to my car.
            • bimmer8604
              • 3017
              been there done that!
              reinforcetime!
              kyle
              1988 M3, 97 840, 99 XJ
              DILLIGAF
              • Funkmasta
                • May 2004
                • 7185
                Mine was doing it in every gear over 1/8 throttle.
                That Guy.
                • FredK
                  • 14759
                  gee Joe, I can't tell what happened. The pix are too small.
                  LUUL. jk. :mrgreen:
                  • Funkmasta
                    • May 2004
                    • 7185
                    LUUL. jk. :mrgreen:
                    Oh, I'll tell you what happened. My car had a Total-System-Failure :D
                    That Guy.
                    • Funkmasta
                      • May 2004
                      • 7185
                      more pics:
                      That Guy.
                      • 86espowa
                        • Jun 2007
                        • 296
                        yeah, thats a part of the subframe i hope to strengthen up a bit when i install the refurbished one.
                        • LINUS
                          • 2422
                          Hey Joe, If you could take a few pics from aways back, then get in close for detail - that would really be helpful since then I'd get a good idea of how to make some re-enforcement plates to weld in.
                          Is this a common issue, and if so has this already been well documemted as to how much metal and where to put it is needed?
                          It's not how you handle the good times, but the faith you keep in the bad that defines you.
                          • Jon325i
                            • 6934
                            How long has your car been in 335 config? Did the subframe have any suspect clues of pending failure prior to the big six?
                            Jon
                            Rides...
                            1991 325i - sold :(
                            2004 2WD Frontier King Cab
                            RIP #17 Jules Bianchi
                            • Ablice
                              • Sep 2006
                              • 261
                              How is it you damaged your subframe when you had the 2.79 diff in with the B25 engine?
                              :mrgreen:
                              Like game music? >clicky<
