Drain Plug Torque Spec?
  • markseven
    • Sep 2006
    • 5327
    Is there a specific torque spec for the engine oil drain plug? I searched the board with no luck, no luck with the Bently, either...
    I Timothy 2:1-2
  • Jscotty
    • Jan 2007
    • 2285
    TIGHT is the torque spec that I use.
    But seriously if you have a good washer behind the plug you should be able to "feel" the proper tightness. Its very difficult to overtighten it with a standard wrench.
    • AlarmedBread
      • Sep 2006
      • 1510
      In the bently
      2:13
      step 4
      24ftlbs ;)
      • markseven
        • Sep 2006
        • 5327
        Yup, pretty much what I have been doing. I just picked up a torque wrench from **gasp** Harbor Fright for **gasp** $14.95 and wanted to try it out.
        Originally posted by AlarmedBread
        In the bently
        2:13
        step 4
        24ftlbs ;-)
        Thanks man! :D I don't know how I missed that
        I Timothy 2:1-2
        • Jscotty
          • Jan 2007
          • 2285
          I only concern myself with the torque when it comes to installing head bolts or other internal engine parts. I find that if I torque most other things to the required specs, its never really tight enough.
          • JGood
            • Jan 2004
            • 7959
            This is OK on some oil pans, but weak aluminum pans, like newer VW's, will wear out and strip VERY quickly with even slight over tightening - so don't make it a habit. When I worked at a lube shop we had charts for torque specs on drain plugs, and you would be surprised how little or high some were. Anything from 15 lbs/ft to 45 lbs/ft IIRC. Always make sure you use a brand new OEM style gasket (whether it's fiber, rubber, copper, or aluminum). Always.
            e30 restoration and V8 swap
            24 Hours of Lemons e30 build
            • uofom3
              • Jan 2004
              • 5392
              turn it as hard as you possibly can to ensure proper tightness - i strongly encourage the use of an air wrench/impact gun.
              PNW Crew
              90 m3
              06 m5
              • Jand3rson
                • 37587
                Ted is right, a breaker bar on the end of your wrench might be a good idea, too.
                But seriously, just good and tight is enough for the drain plug.
                • markseven
                  • Sep 2006
                  • 5327
                  I swear that's what Crevier used on my 540 when they performed Inspection I & II services.
                  I Timothy 2:1-2
