Short shift kit or wheels?
  • Yakinho
    • Feb 2007
    • 650
    I'm getting both, but at the meantime I only really have enough money for one... As far as my shifter, I have 4+ inches of play in each gear... Should I spend a shitload on a uuc kit or just put my own parts together? As far as wheels go, I plan on getting 16X8 rota slipstreams as they look nice and are more in my budget. Opinions please.
  • luTTz
    • May 2007
    • 204
    i have the uuc race shifter and absolutely love it. cheaper and gets the job done.
    • e30lyf
      • May 2007
      • 4516
      get some OEM shifter $70 is not bad. then the rest of your money buy the rims that you want. if it's not enough your $$$ then wait. IMO
      - Fercy -
      Classic BMW Specialists
      Santa Clarita, CA
      www.BimmerHeads.com
      • backtrail69
        • Jul 2005
        • 4471
        Rims, z3 1.9 (or eq) w/ new bushings and it should stiffen that shifter up.
        :: PNW Crew ::
        '87 325 4dr, '74 2002
        • smonkbmw
          Professor
          • Jun 2006
          • 4549
          yeah, understeer kit and use the rest on whatever.
            • 37828
            Just buy a SSK using OEM Z3/Z4 parts.
            Grover Beach, CA
            www.BimmerHeads.com
            • nefarious7907
              • Jan 2005
              • 1170
              I have a 1.9 shifter and its okay, but I will go with a UUC race shifter when I have the funds, 1.9 is flimsy compared to my 24 year old stock shift lever. And 50+% of your play comes from worn shift carrier bushings, not the lever.
              http://www.cardomain.com/ride/657387
                • 37828
                Um ya, that's why you replace all of the bushings too...
                Grover Beach, CA
                www.BimmerHeads.com
                • dj2xrated
                  • May 2007
                  • 540
                  hhahaha.... i say go with da shifter.. unless your having wheel problem with the ladys.
                  Operation S/C E39M5.:woowoo:
                  • kencopperwheat
                    King of Kegstands
                    • 14396
                    Are you implying that the other 50% of the 'play' comes from the lever? I'd venture a guess that >1% of it does... if that.
                    What do you mean the 1.9 is flimsy? Can you easily bend the thing by hand?
                    Originally posted by Gruelius
                    • psloan
                      • 9815
                      I was wondering the same thing.
                      • nefarious7907
                        • Jan 2005
                        • 1170
                        No you think?
                        I only sell poly and derlin bushings for sheet metal and aluminum consoles.
                        But the internal bushing in the shift lever makes it flimsy.
                        I really do not think a brand new OEM BMW lever was going to be that bad. The only benefit of there being flex in a shift lever is if you slam the lever into the gear and flex would cushion the shift a smidge.
                          • 34834
                          my z3 1.9 lever doesn't do that.. it looks like it's broken to me.
                          • Jean
                            • 18228
                            No you think?
                            Can you PM me with what bushings you sell for the metal console ?
                            • egk2
                              • 2426
                              Take care of your shifter issue before going with wheels. I'd rather have a car that works good than a car that looks good but doesn't work good
                              Use oem parts and replace whatevers worn, much more cost effective than a UUC kit although they are nice units. I used the Z4 2.5 lever and replaced everything that I could think of, it was good enough for me and was cheap.
